Just tried to update my Volumio to the latest version that was available through the GUI. System wanted to reboot after the update, but doesn’t boot.
I get 7 flashes from the PI which might mean kernel.img is missing.
Do I have to re flash the image and start from scratch?
Not much other to do then start from scratch. Something went wrong during the upgrade and it’s impossible to narrow down what got broken.
This seems very unique case, so there might be other problems like,
That was what I was a bit afraid of, but did it anyway. Now back up and running after full reset.
Same SD and same PSU still in the system, but working.
Thank you for the help!
