Hello dear users, i hve tryied many times to install volumio but never success, this time i try to do it again with new hardware. I bought rpi5 8gb. My problem is as always cant connect to web ui. No wifi no ethernet possible. Before i got Screen with ip adress i got red screen for about 10minutes like on picture. Had same on pi400 pi4, what i do wrong. Used raspi imager, ether new sd cards.
Please remove everything from your rPi5.
Only connect:
- SD card
- Power supply
- Network cable.
You get all kind of USB errors, so it seems something connected is broken.
**xHC** = xHCI (USB 3.x host controller)
Error **"xHC-CMD err: 4 type: 11"**
indicates a USB command issued by the firmware failed during USB bus enumeration.
I think it was dongle form keyboard or dac2 pro from hifiberry. Thx for hint.
No Need for keyboard, Volumio is a headless system. So most likely that is your problem.
A i2C DAC like the dac2 pro can’t generated USB errors…
Its a live !!! First time ever
im so happy. Even touch display works. Thx for little help. My journey with Volumio just began.
