Files added are deleted on reboot
I want to use the pi which hosts volumio to measure temperature and humidity.
Ive added all the files to do this but when I reboot to start the monitoring python scripts the files have been deleted!
Help! Does anyone know how to prevent the python files from being deleted? :cry:
HCG
Where are you saving the files? Are they just python scripts?
Not all are python scripts … some text files (config) and some library files.
They were put in /home/volumio … I tried to create a new directory under /home but that got deleted too after a reboot
Ive looked at the SSD card outside the pi and its directory structure is quite different … not just /proc directories etc .
So I guess volumio must create the dir structure each time it reboots … I guess Im looking for a place to put my files so that they
can be placed in /home/volumio on reboot. At the moment I set up the pi to do the monitoring and then just dont switch it off … (as
I do normally … for the music). So its not mission critical :slight_smile: but I would like to understand whats happening as I want to create other
volumio pi’s able to monitor temp and humidity.
Volumio uses an overlay and squashfs, which is why things look different on the sd card alone. I don’t understand why you can’t create permanent directories in the home directory though … it works for me here (just tried on a Sparky).
Hi chsims1,
there must be something wrong with that pi … I have another pi with volumio on it and I can add directories to /home on that one.
Thanks for the help
HCG
It’s for sure the power supply then: if it does not give good old 5 volts and 2 A, the sd card does not work properly
