I’m going to try this tomorrow … I do give feedback about how this works / sounds. I also try with an allo isolator in between.
Verstuurd vanaf mijn Nokia 6.1 met Tapatalk
okay i have tried the raspberry pi 4b-2gb model with kali reclocker with the allo piano 2.1 on top.
and I have to admit that there is slightly less detail present and less pronounced sound compared to the raspberry p3 b +.
the video below of hans beekhuyzen also confirms this.
youtube.com/watch?v=cjqEPyMr1zI
furthermore the piano 2.1 only works on dual stereo and only on the outputs of sub-left and sub-right.
on dual mono I only get sound from the right sub-output … so stereo left does not work at all.
I don’t know why that is…maybe my kali reclocker is broken and therefore the left stereo outputs do not work.
the raspberry pi 4b with only the piano 2.1 works great with both dual stereo and dual mono.
Hi - sorry - I’m trying to get volumio running on the PI4 - the current build is crashing with ‘welcome to emergency mode’ - is there a link to the beta I should be using? Thank you!
Any idea what might be causing it? Is there a good place to file a report? Thanks
Volumio works on Rpi4. It seems something is wrong with your image. Download last version of Volumio and reflash it.
A point; the Raspberry Pi Foundation have today announced that the RPi 4 Model B 2Gb is now the same cost ($35) as the 1Gb version, so it’s now the entry level (raspberrypi.org/blog/new-pr … -pi-4-2gb/).
But they haven’t reduced the price of the 4gb…
Hello, does RPI 4 KODI work for you? I only have a black screen and it doesn’t work via my usb keyboard and mouse.
Hi Volumio,
I have a raspberry pi 4 and am trying to install Volumio on it. I have flashed the latest Volumio software using Balena Etcher (onto a USB Drive) and plugged that into the RPi. I have plugged in an ethernet and then power just to get things setup (im hoping to use just wifi on the long run). Unfortunately I do not think Volumio is booting. I cannot access Volumio.local/ and have tried android, Mac and windows devices. I also cannot see a Volumio hotspot on any devices.
Is Volumio compatible with the Raspberry Pi model B? It seems many others have managed to get this working.
u should put it on a sd not usb…
