DSD (DoP) no longer available on my Resolution Audio Cantata 3.0
Hi Firstly I’m not very techie… When playing DSD (over DoP) to my Resolution Audio Cantata 3.0
https://www.resolutionaudio.com/
the display on the Cantata used to show DSD1 which meant DSD64. Since an upgrade towards the end of Volumio 3 (Sorry don’t know exactly which one) DSD now displays as 176kHz (as it would when playing flac files).
I think that Volumio is defaulting to converting the DSD to Flac, is that correct? I’ve just downloaded Volumio 4 and that is the same.
I use a Pi4 connected to Cantata via USB.
Thanks for any help
Regards
McShads
As a follow up is there an archive of Volumio 3 releases where I could download an older version that would work?
*** I’ve just remembered I think the DSD stopped working with the update that increased the partition size ***
for DSD (which has absolutely nothing to do with partition size):
  • Set Playback option to Direct DSD, if the DAC doesn’t support it DSD over Dop.
  • Only use for mixer either None or Hardware
  • Remove any plugin that interfere with the audio path. like FusionDSP.
Some picture to show it works with Volumio 4:
Thanks, Dac only supports DoP. Mixer is set to hardware, no plugins.
It worked perfectly with Volumio 2 & 3 up to a certain update (I’m not sure which exactly)
Is there somewhere I can download an image file of a mid life Volumio 3? I think this will be the easiest option.
Thanks again
Use the search function on the forum.
Not going to support download links to a EOL version of Volumio.
Also over DoP, Volumio V4 it works fine:
Thanks, unfortunately it doesn’t work fine with my Cantata.
I have searched but some of the posts I don’t understand, as I said I’m not very techie.
I can understand an old version is not supported but an old version would allow me to enjoy DSD files again
The very first link using the search function…
Thanks for pointing those out. Unfortunately I need an earlier version than any of those to restore my DoP playback.
More searching suggest I need version 3.546 (27-09-2023) for Rpi or earlier.
Thanks for your help
@McShads
https://updates.volumio.org/pi/volumio/3.546/Volumio-3.546-2023-09-27-pi.zip
https://updates.volumio.org/pi/volumio/3.512/Volumio-3.512-2023-06-25-pi.zip
http://updates.volumio.org/pi/volumio/3.449/Volumio-3.449-2023-03-30-pi.zip
Thank you M1ck, you’re a star!
Installed 3.546 & DSD64 (DoP) is back! Thanks again @M1ck for your trouble.
No idea what changed between 3.546 & 3.779 but whatever it was my Cantata didn’t like it
