Hi - I bought the Rivo + and was under the impression I would be given a premium account, is this the case?
During my first setup attempt I used a free account, then tried setting up again using the NFC access pass, but my account sub is still a “free” one.
Volumio HW comes with a full license.
There is even no need to login, but if you do you can access the plugin store.
It might be that the time/date on the Rivo+ is not synced yet.
Thanks - but how do I activate it? ie on my phone the only way seems to be to use the free account, other than upgrading and paying for it?
no if you open sources you’ll see that all premium services have been enabled.
what source? I used the phone app given with the packaging/ NRC access pass card
The Access pass card should push you through the initial setup. When completed all premium features are activated.
In the Volumio app, click on Hamburger menu (left top, 3 stripes) => Sources.
OK thanks will try again
Ive signed in, and its def the FREE account. Can I upgrade? or will I have to go through setup again and create a new login?
(thanks again for your help)
Ah I think I understand thanks.
So the “Premium” features are already built into the unit? and having a “free” account on my phone dsnt really matter?
Rivo Plus is a premium device, all the premium features are unlocked already.
The myvolumio account is not strictly necessary for the premium features, it is only required to download and install the plugins. You can use a free myvolumio account for this purpose.
