Does Primo use the same volumio under the hood?
Hey, I’m considering the get new streamer to home and was thinking about buying the primo, does it use the same volumio install under the hood with the websocket etc working as it is with for example raspberry installations?
Yes, it runs the same NodeJS backend/front end as regular myVolumio, so websockets should mostly work.
as per https://volumio.org/product/volumio-primo/ it includes:
  • MyVolumio Superstar Lifetime Plan
  • Dedicated e-mail support from Volumio Team.
  • Dedicated support from Retailer.
  • Dedicated support from Distributor.
Nice, thx for fast reply.
Guess i need to put my shopping pants on when i get to vacation after next week :slight_smile:
