I am trying to find a compatible display with volumio and raspberry pi 3 b+ version. Can you please help?
I need something easy to install. I already have the GPIO pins occupied with a DAC, so either a simple old style display or an HDMI one.
Thank you!!
There is a plug in to use this display, but it is not recommended for the B+ version. When I try to install it, it stops at 70%…
gvolt
4
If you had a USB keyboard attached while installing the plugin try it again without the keyboard. The issue reported here https://volumio.org/forum/touch-panel-bugs-128-and-129-t6284.html and here https://volumio.org/forum/error-touch-panel-installation-volumio-123-t6163.html might still be present.
P.S. Are there any specific issues why the plugin would not be recommended for the PI 3 B+ ?
Thank you very much!! It works fine now, it was the usb keyboard.
I was pressing the “Detail” of the plug and was getting the following info
gvolt
6
Great it’s working!
I see, but “Pi B+” is a shortcut for the “Pi 1 B+” and does not mean the “Pi 3 B+”.
Ge0rge
7
It makes sense, thank you!!
I am very new to raspberry and volumio…
