Hi all,
thank you for the great work of volumio 2.0. I read https://volumio.org/discover/ about plugin support like Spotify and Digital Room Correction. I cannot find where is located Digital Room Correction on the repository. Can you give me a hint?
Thank you
Drc plugin is still in dev. No really usable version is available yet. It will provide we gain /phase, stereo to binaural Bauer filter, and the use of personal filter file for etc. Keep in touch:-)
hey ! do you have some news about the DRC plugin ?
Would love to test it ! as a mastering engineer and acoustic enthousiast !
Hi!
Sorry to said that no work has been done since several week… But, even if the plugin is not finished yet, some part is working : brutefir works and can be use with personnal filter. What is not working : equalizer and volume control.
But if you don’t use volume control in volumio, you can test it with you own filter. Just install https://github.com/balbuze/volumio-plugins/blob/master/plugins/miscellanea/brutefir/brutefir.zip
It also provides a binaural Bauer filter
After install reboot, the select the Loopback device in output. Go in plugin settings, select advanced settings and choose the right output ( 1 or 2 or often 5 for usb device) use aplay -l to determine the good. You can check if brutefir is running with
systemctl status brutefir
If ok , good. Place you own filter on the device and give the path in good fields (left and right). And let me know !
I agree it is not very convenient, it requires a file selector…
Have a look at the readme.md https://github.com/balbuze/volumio-plugins/tree/master/plugins/miscellanea/brutefir
I found this thread, when I searched information about DSP for room correction. The name of this thread is very attractive.
Only for clear understanding. This thread is dead. Plugin is in version 2 volumio2-and-brutefir-t4151-180.html
It is correct?
Good luck getting a reply.
But I’m sure it is possible, as miniDSP just came out with a box containing Volumio, EQ, XO for 4 channels and Room Correction included.
What is the model name for the minidsp?
It’s a new line called SHD.
Shipping in July, pricing not available yet…
Check it out on their website. Looks pretty good.
Thanks for link to minidsp. I suppose, it will be expensive. I discovered a simple equalizer plugin in volumio GUI. I will try this one.
It might be expensive, but pricing is not out yet. We’ll see.
I’ll have a look into the EQ in Volumio, but I would love a convolution plugin!
Here a plugin using a convolution engine brutefir. Keep in mind it’s still in development but usable within conditions…
github.com/balbuze/volumio-plug … /brutefir2
