Hi all.
So, fairly new to stereo equipment and Volumio.
I wanted to make a setup, with a streamer able to do a bunch of various sources - so naturally Volumio popped up.
So, I bought a Digione Player (Digione+RPI3). My plan was to install a touchscreen to allow girlfriend and guests to control volume and music from a touchscreen at the stereo and also via their own smartphones, but I’ve recently been educated about the software volume issues.
So, in short - is it possible to control the volume from a touchscreen on Volumio without degrading the sound quality - or is that simply the inherent problem of using a Raspberry Pi with a Digital output, that you can’t control the volume on (for instance) Volumio without degrading sound quality?
Thanks in advance.
