hints-and-solutions/51707 before posting a new issue.
I have just replaced my old Raspberry Pi Arcam Dac and the Volumio App as the Dac went faulty.
I have replaced it with a new Rasperry Pi 5 4 GB and a Hi Fi Berry Dac 2 HD but the system will now not connect to Volumio. The Pi light stays red and is not flashing and I am using version 5.260413.0 of Volumio. I have also tried using 2 different SD cards but no difference. Any suggestions please
Hi @ChrisM1
1st, There is no V5.xxx of Volumio. It’s either V3.xxx or V4.xxx
2nd, From where did you download the image
3rd, Did you unpack the zip file and flashed the *.img file to the SD (Not the zip file), using Raspberry Pi Imager
He is referring to the app version listed on an iPhone. My Volumio app version matches what he posted.
The app is not the issue here.
The image seems to be the culprit.
I was with Chris. We tried 3 SD cards in his new Pi.
- the Volumio install he had previously been using with his old Pi,
- my current MoOde install, and
- a card I flashed today with Volumio; flashed using Raspberry Pi Imager.
The Pi’s green LED stayed solid, no flashing which I would expect when booting up.
Please answer the questions asked first.
Now we have 2 opposite statuses.
Chris states solid red, you state solid green.
Solid red => Power present, but boot didn’t start
Solid green => System is up and running.
@ChrisM1 what do you have now? We had solid green earlier.
Hey @ChrisM1,
Before going further on image or flash method, confirm the power supply. Pi 5 negotiates USB-C PD and is strict about it. A solid red LED with no green activity is the classic signature of an inadequate or non-PD supply. A Pi 4 brick, a phone charger, or a generic USB-C PSU will often sit red on a Pi 5 even when the identical SD card boots fine on a Pi 4.
This also fits the LED contradiction with @ICLlP, who saw solid green earlier.
Post the make, model, and rated output of the PSU you are using, and if possible test with the official Raspberry Pi 27W USB-C supply.
this is definitely not good for a RPi5
@Darmur, why would this not be good? The spec suggests it should be, does it not?
@Wheaten, the Volumio image used was the 2026-02-27 release as selected by Raspberry Pi Imager.
Don’t use the image provided by raspberry, only the one from Get Started - Volumio
Many people have reported issues with the one from the raspberry tool.
