Daylight saving time
Hi
Having trouble getting the time config right on my Volumio box.
catman@masterbedroom:~$ sudo timedatectl
Local time: Sun 2018-03-25 08:42:52 UTC
Universal time: Sun 2018-03-25 08:42:52 UTC
RTC time: n/a
Time zone: Europe/London (UTC, +0000)
NTP enabled: yes
NTP synchronized: yes
RTC in local TZ: no
DST active: n/a
As of this morning DST should be active, but I can’t find a setting in the UI or a timedatectl to turn it on, as it were.
What do I need to do?
TIA
C
sudo cp /usr/share/zoneinfo/Europe/London /etc/localtime
or you could symlink it.
That’s great, thanks. I spent hours googling :frowning: My linux skills are weak these days. Too much time sitting in meetings and not enough driving a terminal!
C
