Correct settings for a Raspberry Pi DAC PRO?
What are the proper playback settings for the Raspberry Pi DAC Pro in Volumio?
I tested the Raspberry Pi DAC+ profile and it works fine, but I’m unsure whether the correct choice should be IQaudio DAC+. It might be placebo, but I feel the sound quality is slightly better with the Raspberry Pi DAC+ setting. Any advice would be appreciated. Thanks.
Hi @mariocco
If it sounds better to your ears, stick with it. The Raspberry Pi DAC Pro was previously called the IQaudio DAC Pro and not IQaudio DAC+ so neither are exactly what you have.
