Control4 Integration
Hi!
I’ve had a search around on here and I can only find talk of integration the wrong way round, i.e. volumio adjusting the volume on a control4 amplifer. Has anyone looked into writing a Control4 driver for Volumio, so that volumio can be controlled from the Control4 app? It would make a great addition to any Control4 system as streamed outputs are only found on the Control4 processors, so to have more streamed sources you have to add more processors, which is an expensive way to do things. There are third party boxes with multiple streams , but these are very expensive.
Thoughts…
