L’applicazione “Volumio” che ho sul mio cellulare aggiornato all’ultima versione “Android”, impiega tantissimo a tempo a chiudersi. Clicco su “Esci” e in modo ininterrotto compare il cerchio girevole all’infinito.
Ho la ultima versione di Volumio. Stessa esperienza anche voi? Ragazzi di “Volumio” state provvedendo? Non se en può più. E’ frustrante! Meno tempo per riaprirsi. Clicco su icona Volumio e dopo cinque minuti mi compare la scritta “Select a device”
Sorry Valentino_Visone, please post in english.
translation:
The “Volumio” application that I have on my mobile phone updated to the latest “Android” version, takes a long time to close. I click on “Exit” and the infinitely revolving circle appears continuously.
I have the latest version of Volumio. Do you have the same experience? Guys of “Volumio” are you providing? He can’t anymore. It’s frustrating! Less time to reopen. I click on the Volumio icon and after five minutes the message “Select a device” appears
Hi can you give details on:
- Which android device are you using
- Which android version are you referring to, as “The latest” doesn’t give any information
Got the same issue as Valentino’s. Please fix it!
