Separating out problem from the original post in ‘Volumio Changelog’ thread as requested by the forum admin, apologies admins I have no clue how to split the post out of the thread into a new topic (as I saw was done by another admin for other issues posted in that ‘Volumio Changelog’ thread)
https://community.volumio.com/t/volumio-changelog/1446/29?u=tidgee
CHANGELOG 3.569
“Fix wrong reporting of playing track in some occasions”
Still seems to be a random problem (for me at least) following the update (using the manifest interface), only correlation I see (between it being a problem or not) is that if you start up the RaspberryPi and then start play music it works okay, but if you start playing around (like switching to look at the play queue or looking around elsewhere) it starts getting stuck on the that track in the ‘now playing’ screen but is still progressing in the play queue (hence displaying the wrong info for the track actually playing).
Update; still a problem but I found a workaround, restarting the system seems (seems, fingers-crossed) to stop the problem but you will need to do this each time it starts mucking around and displaying the wrong ‘current track playing’ info.
