Can't Play Spotify or Networked Music
I have a raspi 3 with the justboom dac, touchscreen and remote control.
It plays the inbuilt web radio no problem and will navigate spotify and also music folder on NAS but will not play any songs of either,
I have tried rebooting, updating system and plugins but it still won’t work. I have tried from the touchscreen, web browser control and I also purchased the app for ipad but they all do the same.
Is there anything I’m missing?
You might want to try playing some songs from both your NAS and Spotify, and then send a log. Don’t forget to post the link back here.
Don’t know how to get logs but I have had some success with the issue.
I have mounted my nas in volumio using the my music library and now I can play the songs. Interestingly I can now play spotify. Trying to play nas music via dlna or server streaming does not work, you can browse and select songs but they will not appear in queu.
I have identified the spotify issue as being with the particular artist I am trying to play, Dwight Twilley Band, adding any of their songs or albums reults in the last successfully played song replaying. They are an obscure 70s group but they are listed on spotify so should work.
I encountered another issue where the que keeps repeating unless you turn the repeat control on, so it is working opposite now to how it used to (I define on as the symbol is white after clicking on it).
