Can't find DLNA server
I have a BubbleUPnP/MiniDLNA server on my network. Every device can see it on my network except for my RPi running Volumio. What could be going wrong?
Have you enabled: uPnP renderer in sources?
Yes, please see screenshot.
Oddly enough, after spending the day at work, I came home and found that my DLNA server is now visible. Why it would take hours to appear is baffling!
Even more baffling is that it has now gone away again.
What’s going on?
This is a longstanding issue. What fixes it for me is to turn UpNP Browser off and on.
I have suggested several times to add this toggle to the boot sequence of Volumio if the issue cannot be solved otherwise.
Thank you for your reply. That worked for me as well.
I also find that I get an error when attempting to play from a DLNA source when the Squeezelite plugin is enabled; since the majority of my listening is through Squeezelite (via Roon), I’ll probably just pass on DLNA.
