Hello to everyone. I have a Sony Ta-zh1es dac, but when I disable the volume control, it still return to Hardware mode everytime. Why? I want to disable volume control. I have a raspberry pi4 model b, and volumio is updated. Thanks a lot.
This often happens when Volumio loses connection with the DAC’s hardware mixer during a reboot or source switch, causing it to fall back to default settings. Try unplugging the Sony DAC, changing the setting to ‘None’ or ‘Software’ in Volumio, saving it, and then plugging the USB back in.
