The notes in the previous post say , ‘vers=1.0’, but you’ve shown you entered that as, ‘ver=1.0’.
Check the entries and try again.
yes, I checked it with vers, was indeed a typo
in CIFS
Error in adding network drive
(22): Invalid argument Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
in NFS
exec error Error: Command failed: /usr/bin/sudo /bin/mount -t nfs -o ro,soft,noauto,‘vers=1.0’ ‘r2d2:/Volume1/Music’ ‘/mnt/NAS/R2D2’
settings:
admin had read/write rights for the share
NFS settings:
Problem solved: I had a comma and a dot in my password…
I am having some issue mounting the nfs share on my synology nad. .
It use to work but suddnly did not work.
I have deleted and add it again like in volumio help. I did not change anything on server side.
Volumio 2.853
I have this error. I have tried for about an hour :(.
Blockquote
Dec 01 20:23:02 volumio volumio[1039]: info: Adding a new share
Dec 01 20:23:02 volumio volumio[1039]: info: No correspondence found in configuration for share Synology on IP 192.168.1.151
Dec 01 20:23:02 volumio sudo[3345]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t nfs -o ro,soft,noauto 192.168.1.151:/volume1/Music /mnt/NAS/Synology
Dec 01 20:23:02 volumio sudo[3345]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dec 01 20:23:02 volumio sudo[3345]: pam_unix(sudo:session): session closed for user root
Dec 01 20:23:02 volumio volumio[1039]: info: Error mounting Synology on IP 192.168.1.151 : exec error Error: Command failed: /usr/bin/sudo /bin/mount -t nfs -o ro,soft,noauto ‘192.168.1.151:/volume1/Music’ ‘/mnt/NAS/Synology’
Dec 01 20:23:02 volumio volumio[1039]: mount.nfs: access denied by server while mounting 192.168.1.151:/volume1/Music
This is the IP of RPI with nfs share.
Update
Blockquote
volumio@volumio:/$ sudo systemctl status nfs
● nfs.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
volumio@volumio:/$
Blockquote
volumio@volumio:/$ sudo showmount -e 192.168.1.151
Export list for 192.168.1.151:
/volume1/Music 192.168.1.191,192.168.1.90
My volumio IP is .191 , so appears as shared .
Many thanks
Hi shiraz I have a synolgy NAS too and they keep changing the UI around so now cant find NFS settings like you displayed. can you point me in the right direction to find them? Thanks
fixed thanks anyway
Subject Volumio is not recoqnizing my nas
I tried to mount my NAS with Volumio Primo software
Problem mnt/NAS/Synoly mount.nfs: access denied by server while mouting
Fillin:
Alias Synology
NAS IP 192 ect without port adres
pad 5000\Volume 1\Muziek
tried also
\Volume 1\Muziek
\Volume1\Muziek
\naspadname\Muziek
type nfs
user first special user : Audio
tries also admininator
Option leave blank
NAS : reboot, set NFS and rights
I tried everything i could find , but with no success
Who can help me
Now volumio primo for me is useless (cost lot of time and does not work at all)
Did you try this Mounting an NFS Share - Volumio Documentation ?
