Hey, decided to put volumio on new RPI 4 and proceeded as usually, but this time it seems to be impossible to login to MyVolumio.
if my memory serves me correctly, last time i did this during volumio 2.xxx there was no issues with it, thought i had a network cable plugged in that time, now i do not have the same opportunity.
Edit: And yes my internet is totally fine, as everything else is working as expected.
Edit 2: okay, it seems that to be able to setup it wireless you do need the official android app for that, it does what i suspected, sets the network before asking for login, where as the automatic popup thing(screenshot above) tries to login before setting network which obviously cannot work unless you have network cable plugged in.
Perhaps this could be fixed in upcoming releases, or disable the auto redirect when entering volumio hotspot all together.
