Cannot connect to ALLO – The BOSS Player
Hallo together,
i am new here, i am new to the BOSS and i am new to raspberry.
Yesterday i got the ALLO – The BOSS Player and until now i try to connect to the web-ui.
I see the hotspot on my old XP and my new win10. I can connect to this hotspot (with the volumio2 pwd).
But nothing happens when i use then “192.168.211.1” or via “http://volumio.local
Also (when connect with the ethernet-cabel) i see packages (network monitor) changed between win-os and the raspberry,
when i use “volumio.local” or also my local IP-address.
But nothing happens, not even an error message.
Btw: I cannot connect with my androit tablet, too.
Please help :slight_smile:
try disconnect Allo Boss from RPI a check volumio.local. Or you can try clean installation (download latest volumio to your micro SD card) and check volumio.local.
Hi… try volumio
Worked for me…
Hi together,
clean installation (new image) was the solution :wink:
thank you very much, xlisec!
:smiley:
