Hi All
I am trying to update my RP4 to the latest version of Volumio
I have turned off all my “add on’s”
But I get the attached error message.
I don’t want to reinstall the new OS, and all the plugins .
Can someone advise?
Many thanks
What plugins are installed?
What modifications did you do on the system?
Send log please but I’m afraid you need a factory reset.
I have Peppy Meter installed
Probably the issue
i had to uninstall peppy to update. then reinstall it.
Mmm, thanks, I guess I will need to do the same
Thanks🙈
