Can not control the sound
I can not control the volume from Volumio Web UI.
Is there some specific settings to enter when using an Rpi DAC ?
(DAC: audiophonics.fr/fr/dac-et-i … 10296.html)
Thanks !
Es9023 does not provide hardware mixer. If you want to control the volume you have to use software volume in playback settings.
Do you mean via the Playback UI ?
That is not working, I can see the volume disk moving but no impact on the actual sound volume.
(For info, I’ve set the DAC config in Settings to be “Hifiberry DAC”.)
Thanks for your help
