Brand new and clueless after searches
First time I’ve ever seen a Raspberry Pi was today. RPi 4 with RPi touchscreen, OS loaded and Volumio flashed. Upon powering on, Volumio goes through startup and then stops at QR code and “volumio login:” I logged the IP address in on my computer and installed the “Pi Screen Setup 8.1”, but still can’t get any activity on the touchscreen. Lost.
The fact tat you see the QR-Code, means that the display is properly recognized.
Now you need to install the Touch Display plugin, in order to get the kiosk visible on your screen.
So you are almost there
Thank you! I think I installed the wrong plug in.
Glad it worked out for you.
You didn’t install the wrong plugin, you only forgot one :grinning:
:+1:
