got it running with Volumio 2.296
How i can Adjust the Volume? My Bose Sound Box did not react on input from the website - is there something else to configure?
Hello
where can i find the latest version of this plugin; understand its not fully maintained but want to give it a try
i also understand it might be part of standard volumio package; anyone knows when ?
could not find it on the list of plugins here volumio-plugins-collection-t6251.html
nor in the volumio plugin management interface
any help appreciated
mavericks solution works perfectly with my Raspi 3 B+ and an Anker SoundCore 2.
I had quality problems (mentioned earlier in this thead) if WLAN and Bluetooth were active. These problems are gone with Bluez Alsa version 1.4, so if you do want to use the internal WLAN and Bluetooth you should change line 9 of the install script to:
git clone -b v1.4.0 --single-branch https://github.com/Arkq/bluez-alsa.git
Iāve tried maverickās solution on Raspberry Pi 3 B+ with the latest Volumio build :
2.657 18-10-2019
NEW FEATURES
Bluetooth A2DP Audio Playback for MyVolumio Virtuoso and Superstar Users
Also tired bluez-alsa version 1.2.0 ā 1.4.0. - 2.0.0
No luck.
Just to check hardware on a a plain Raspbian Buster I was able to connect the BT Speaker and play without problem.
Have anyone been able to make it work with latest builds?
still no working solution for version 2.668 ?
I like volumio ⦠but this Post Starts 2017 ā¦
Is there any chance that this here will be an really volumio Plugin which can be installed via UI from the repository.
Not every user of volumio is a linux nerd.
Regards
Jürgen
Hi
Where can I find this plugin?
Regards
Can I use this plugin to output to Volumio? I have Amazon Kindle 7 inch, and sometimes sound is not loud enough.
Iād like to use the speakers connected to Volumio.
Initially I tried to re-route the sound output to Volumio via an app, but failed. So I want now to try bluetooth.
Iāve not installed the plugin, cause Volumio (v2.729) want install it.
But, as Volumio is just an interface between human and digital music machine, Iāve compiled the latest bluez-alsa 2.1.0 (github.com/Arkq/bluez-alsa/archive/master.zip) and ⦠it works not so bad.
We can now compile bluez-alsa with openaptx (github.com/Arkq/openaptx) to enable the aptx and/or aptx-HD BT protocols.
Of course Volumio have no idea that this alsa plugin is installed, so the Volumio volume canāt change for the bluetooth device (but the alsamixer will).
/lib/systemd/system/bluezalsa.service
[Unit]
Description=BluezAlsa proxy
Requires=bluetooth.service
After=bluetooth.service
[Service]
Type=simple
User=root
Group=audio
Environment="LIBASOUND_THREAD_SAFE=0"
ExecStart=/usr/bin/bluealsa -p a2dp-sink -p a2dp-source
[Install]
WantedBy=multi-user.target
#Added this lines
audio_output {
type "alsa"
name "BT Headphone"
device "btspeaker"
mixer_type "software"
[code]
pcm.btspeaker {
type softvol
slave.pcm ābtspeakā
control {
name āBluetoothā
card 0
max_dB 0.0
min_dB -50.0
resolution 100
pcm.btspeak {
type plug
slave {
format S16_LE
rate 44100
pcm {
type plug
slave.pcm {
type bluealsa
device āXX:XX:XX:XX:XX:XXā # BT device Mac Addr
profile āa2dpā
hint {
show on
description āBluetooth Speakerā
}[/code]
This configuration do not change the main Volumio output so youāve have to mute it to listen only through the BT device.
(backups those files as Volumio will overwrite your changes each time you change your Volumio settings)
As I have several BT audio devices Iāve made a small bash script to connect the one I want (you may also use this script to check and test your configuration. You must pair and trust you BT device(s) with the ābluetoothctlā command, before to use it).
Here is the script:
#!/bin/bash
# This script check and test your BT configuration (bluezalsa & mpd.conf).
# Connect the choosen BT device, disconnect the others, create the file /etc/asound.conf, run a sound test
# and restart the mpd service
if [ "`whoami`" != "root" ] ; then
echo "Please use : sudo $0 "
exit
fi
device_name=''
detectedindex=''
newindex="N"
DIR=`dirname $0`
clear
alsaconf="
#####################BLUETOOTH AUDIO CONF######################
pcm.btspeak {
type plug
slave {
format S16_LE
rate 44100
pcm {
type plug
slave.pcm {
type bluealsa
device \"DEVICE_MAC_ADDR\" # BT PLUGIN (DO NOT MODIFY THIS COMMENT)
profile \"a2dp\"
hint {
show on
description \"Bluetooth Headphone\"
pcm.btspeaker {
type softvol
slave.pcm \"btspeak\"
control {
name \"Bluetooth\"
card 0
max_dB 0.0
min_dB -50.0
resolution 100
#####################END BLUETOOTH AUDIO CONF######################
# DO NOT PUT ANYTHING AFTER THIS LINE
# Check if bluezalsa is running
if ! systemctl is-active --quiet bluezalsa ; then
echo "Bluezalsa is not running ? Please install and start bluezalsa (see https://github.com/Arkq/bluez-alsa)"
exit
fi
# Check if mpd.conf know the "btspeaker" device
if ! grep "device" /etc/mpd.conf | grep "\"btspeaker\"" > /dev/null ; then
echo "Your /etc/mpd.conf seems to not have bluetooth speaker configuration ?"
echo -e "You must put this lines :\naudio_output {\n type \"alsa\"\n name \"Bluetooth Speaker\"\n device \"btspeaker\"\n mixer_type \"software\"\n} \n in the # Audio Output ## section of your /etc/mpd.conf file."
exit
fi
# List of already paired Devices
i=0
for DEVADDR in `echo -e "paired-devices\nquit" | bluetoothctl | grep "^Device " | awk '{print $2}'`
do
devices_addr[$i]=$DEVADDR
let "i++"
done
i=0
for DEVNAME in `echo -e "paired-devices\nquit" | bluetoothctl | grep "^Device " | awk '{print $3}'`
do
devices_name[$i]=$DEVNAME
let "i++"
done
if grep -q "##BLUETOOTH AUDIO CONF##" /etc/asound.conf ; then
device_addr=`grep " device \"..:..:" /etc/asound.conf | awk '{ print $2}' | sed s/'"'/''/g`
else
cp /etc/asound.conf $DIR/asound.conf-volumio && echo " ### The original /etc/asound.conf has been saved as $DIR/asound.conf-volumio . PLEASE, DO NOT DELETE THIS FILE. ###"
device_addr=""
fi
echo -e "\nList of already paired BT Devices\n#########################################"
for index in ${!devices_addr[*]}
do
asterix=" "
if [ "${devices_addr[$index]}" = "$device_addr" ]; then
detectedindex=$index
device_name=${devices_name[$index]}
asterix="*"
fi
echo "${index})${asterix}Device ${devices_name[$index]} (Addr : ${devices_addr[$index]})"
done
connected=`echo -e "info ${devices_addr[$detectedindex]}\nquit" | bluetoothctl | grep "Connected:" | awk '{print $2}'`
actualdeviceconnect=""
if [ "$connected" = "yes" ]; then
actualdeviceconnect="(this device is actually bluetooth connected)"
fi
echo -e "#########################################\nREM : The device preceded by '*' is the actual bluetooth audio device detected in /etc/asound.conf $actualdeviceconnect\n"
if [ "x$detectedindex" = "x" ]; then
read -p "Is your BT device in the list before (already paired)?[y|N] : " ans
ans=${ans:-'N'}
if [ $ans != 'Y' ] && [ $ans != 'y' ]; then
echo "OK. Please use the 'bluetoothctl' command to pair and trust it, then run this script again. Bye!"
exit
fi
fi
num='^[0-9]+$'
while ! [[ $newindex =~ $num ]] ; do
read -p "Which BT device do you want to connect ? Enter his number [$detectedindex] : " newindex
newindex=${newindex:-${detectedindex}}
done
ntd=0
if [ "$newindex" = "$detectedindex" ] && [ "$connected" = "yes" ]; then
echo "From my point of view, everything seems to be good."
ntd=1
fi
# We disconnect all other devices
do
if [ "$index" != "$newindex" ] ; then
echo -e "disconnect ${devices_addr[$index]}\nquit" | bluetoothctl > /dev/null
fi
done
echo "All other BT devices connected have been disconnected."
if [ "$newindex" != "$detectedindex" ]; then
if [ ! -f $DIR/asound.conf-volumio ] ; then
echo -e "Oups!? I've not found the $DIR/asound.conf-volumio ? But I need it.\n I'll try to restaur it ...."
asoundconf=""
nl=""
flag=0
while IFS= read -r LINE; do
if [[ `echo "$LINE" | grep "##BLUETOOTH AUDIO CONF##"` ]]; then
flag=1
break
else
asoundconf="${asoundconf}${nl}${LINE}"
nl="\n"
fi
done < /etc/asound.conf
echo -e "$asoundconf" > $DIR/asound.conf-volumio
if [ "$flag" = "0" ] ; then
echo "Failed to restaur the original /etc/asound.conf. Please \"Save\" your Audio Output configuration again in the Volumio Setup Configuration"
exit
else
echo -e "\n Yep! Original asound.conf has been restaured in $DIR/asound.conf-volumio, please check it.\n If it's not correct, abort this script and \"SAVE\" your Audio Output configuration again in the Volumio Setup Configuration. Rerun this script after that."
read -p "Type 'Enter' to continue or anything else to abort " ans
ans=${ans:-'Y'}
if [ "$ans" != "Y" ] ; then
exit
fi
fi
fi
cp $DIR/asound.conf-volumio /etc/asound.conf
echo "$alsaconf" | sed s/"DEVICE_MAC_ADDR"/"${devices_addr[$newindex]}"/ >> /etc/asound.conf
device_addr=`grep " device \"..:..:..:..:..:..\" # BT PLUGIN" /etc/asound.conf | awk '{ print $2}' | sed s/'"'/''/g`
if [ "$device_addr" != "${devices_addr[$newindex]}" ]; then
echo "Error! Check the /etc/asound.conf. Something may be wrong :-( "
exit
fi
device_name=${devices_name[$newindex]}
fi
# May be the /etc/asound.conf has been modified
if [ "$ntd" = "0" ]; then
/usr/sbin/alsactl -L -R nrestore
fi
connected=`echo -e "info $device_addr\nquit" | bluetoothctl | grep "Connected:" | awk '{print $2}'`
if [ "$connected" = "yes" ] ; then
echo "Device $device_name is already connected"
fi
else
echo "Device to connect : $device_name (addr:$device_addr)"
read -p "Switch on your device and press Enter to continue ..."
echo -n "Trying to connect your device.."
echo -e "connect $device_addr\nquit" | bluetoothctl > /dev/null
echo -n "."
i=0
while [ $i -lt 5 ]
do
sleep 1
echo -n "."
let "i++"
done
echo -e "\nDevice $device_name is now connected!"
else
echo -e "\nFailed to connect. Check your device and try to run this script again, if it fails then restart bluezalsa service or reboot your Pi, before running it again."
exit
fi
fi
# Now a small TEST
if [ ! -f $DIR/test.wav ]; then
echo "To make a test, I will download a small simple audio file from the McGill University(Canada) in $DIR/test.wav"
read -p "Are you OK [Y|n]?" ans
ans=${ans:-'Y'}
if [ "$ans" = "Y" ]; then
wget -q -O $DIR/test.wav "http://www-mmsp.ece.mcgill.ca/Documents/AudioFormats/WAVE/Samples/AFsp/M1F1-int32-AFsp.wav"
fi
fi
if [ -f $DIR/test.wav ]; then
read -p "I will now play a short audio test. Are you ready? Type 'Enter'" ans
aplay -Dbtspeaker $DIR/test.wav
read -p "Did you ear the voices ?[Y|n]" ans
ans=${ans:-'Y'}
if [ "$ans" != "Y" ]; then
echo "Sorry, there is nothing I can do. May be you can try to reboot your Volumio?"
exit
fi
else
echo "Sorry I was unable to download the test file."
fi
# Restart MPD
read -p "We will now stop current play if any, clear the queue and restart MPD. Type 'Enter' to continue (or anything else to abort)." ans
ans=${ans:-'Y'}
if [ "$ans" = "Y" ] ; then
volumio stop
echo ""
sleep 1
volumio clear
echo ""
sleep 1
systemctl restart mpd
sleep 1
systemctl is-active --quiet mpd && echo "MPD is successfully restarted! Wait a minute before launching a new song."
i=60
while [ $i -gt 0 ]
do
sleep 1
if [ $((i%5)) = 0 ]; then
echo -n "$i"
else
echo -n "."
fi
let "i--"
done
echo "Have fun!"
else
echo "OK, MPD not restarted. You know what you're doing. Bye, bye...";
fi
Hi domcars0,
I have tried to run another install script that someone mentioned a bit before but this did not work, now I am trying to reinstall bluez-alsa but I donāt seem to get it working. If I could do a fresh install on that, I could follow your instructions and maybe get it working.
We did a new install, we could pair, connect, ⦠bluetooth, but no sound out of it.
Thanks for helping.
Luc
Hi domcars0,
Thanks for helping.Luc
Hi Luc,
Did you try the alsamixer command?
May be your BT volume is too low ?
With my script did you ear the voices from the sample wav file ?
Bye.
I tried everything, but only sound from HDMI on screen or Audio Jack (headphone), nothing from bluetooth speaker.
We tried the alsamixer, but only alsa is visible.
No sound coming from file, give error on pcm
Hello there, i Have the follwing problem with the install. In the first post thereās following step:
Restart and afterwards you can install the plugin by drop the bluetooth_controller.zip into the plugin upload.
Where is this upload folder? And is it right just to drop the zip there or do i have to extract the content to that folder? I use FileZilla to copy files, but i canāt see any plugin upload folder but there are lot of plugin/plugins folders. So iām confused where to copy ![]()
I canāt run this plugin at all. Iām trying to run it on Pi 4.
here are logs:
Jun 13 06:13:14 volumiodoctord volumio[1085]: info: Enabling plugin bluetooth_controller Jun 13 06:13:14 volumiodoctord volumio[1085]: info: Loading plugin "bluetooth_controller"... Jun 13 06:13:14 volumiodoctord volumio[1085]: error: !!!! WARNING !!!! Jun 13 06:13:14 volumiodoctord volumio[1085]: error: The plugin audio_interface/bluetooth_controller failed to load, setting it to stopped. Error: Error: Cannot find module '/data/plugins/audio_interface/bluetooth_controller/node_modules/udev/build/node-v57-linux-arm/udev.node' Jun 13 06:13:14 volumiodoctord volumio[1085]: error: Stack trace: Error: Cannot find module '/data/plugins/audio_interface/bluetooth_controller/node_modules/udev/build/node-v57-linux-arm/udev.node' Jun 13 06:13:14 volumiodoctord volumio[1085]: at Function.Module._resolveFilename (module.js:547:15) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Function.Module._load (module.js:474:25) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Module.require (module.js:596:17) Jun 13 06:13:14 volumiodoctord volumio[1085]: at require (internal/module.js:11:18) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Object.<anonymous> (/data/plugins/audio_interface/bluetooth_controller/node_modules/udev/udev.js:4:12) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Module._compile (module.js:652:30) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Object.Module._extensions..js (module.js:663:10) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Module.load (module.js:565:32) Jun 13 06:13:14 volumiodoctord volumio[1085]: at tryModuleLoad (module.js:505:12) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Function.Module._load (module.js:497:3) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Module.require (module.js:596:17) Jun 13 06:13:14 volumiodoctord volumio[1085]: at require (internal/module.js:11:18) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Object.<anonymous> (/data/plugins/audio_interface/bluetooth_controller/AVRCP.js:2:12) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Module._compile (module.js:652:30) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Object.Module._extensions..js (module.js:663:10) Jun 13 06:13:14 volumiodoctord volumio[1085]: at Module.load (module.js:565:32) Jun 13 06:13:14 volumiodoctord volumio[1085]: error: !!!! WARNING !!!! Jun 13 06:13:14 volumiodoctord volumio[1085]: info: Done.
I was able to get volumio on both of my raps-pi thanks in large part to @Fosphatic_Duke and @maverick, with help from the docs for blue-alsa. My volumio version is 2.799 and my bluez-alsa is 2.1.0. Iām not even going to pretend I understand the alsa or bluetooth protocols well and I am using the snapcast plugin - which seems to be a shaky component to build upon - so ymmv and I likely canāt help w/ yr specific set-up, tho Iāll try.
I started with steps 1 and 2 from the āInstallation From Sourceā guide on the bluez-alsa github page. As of now, that entails:
sudo apt-get install git automake build-essential libtool pkg-config
sudo apt-get install libasound2-dev libbluetooth-dev libdbus-1-dev libglib2.0-dev libsbc-dev
to get the tools and libraries required. Nothing new there. And nothing new in the pre-build process:
git clone https://github.com/Arkq/bluez-alsa.git
cd bluez-alsa
autoreconf --install
mkdir build
cd build
The build configuration is a bit of hybrid from the three aforementioned sources. The two contributors here had:
../configure --disable-hcitop --with-alsaplugindir=/usr/lib/arm-linux-gnueabihf/alsa-lib
--disable-hcitop did not seem to be necessary given the defaults, but it caused no harm, so I left it. The second option I didnāt fuxx w/, but itās working, so I assume bluez-alsa needs the direction to that folder.
I did need one of the options from the docs that wasnāt mentioned above. I donāt know what the mechanics of --disable-payloadcheck are, but it says if you have pulseaudio version < 13, youāll need it, and I do and did. So my config command ended up being:
After that finishes, the usual make commands:
make
sudo make install
Cool. It builded. Now to create the service file.
sudo nano /lib/systemd/system/bluezalsa.service
Itās the same as the above with one important omission. Disabling hfp definitely seems to be the correct thing to do, but bluez-alsa was complaining that it wasnāt a recognized option. I guess defaults have changed or something. So we end up with:
[Unit]
[Service]
Type=simple
User=root
Group=audio
[Install]
Then reload the daemon and enable the service:
systemctl daemon-reload
systemctl enable bluezalsa.service
Now use bluetoothctl to get the MAC address of the player you want to connect with. There are plenty of resources to figure out how to do that so Iām skipping.
Everything up to this point has been straight from the help except the options that I was forced to add or delete to get it to install and run. From here on out, I had to make some decisions and adjust some things to work with the snapcast plugin. I donāt know if these are the best decisions, but I made them and they seem to be working.
I decided to put my alsa config in /etc/asound and use the ādefaultsā idiom because I figured Iām only interested in connecting to one device and I only have one bluetooth controller on the pi.
nano /etc/asound
and add
defaults.bluealsa {
device "xx:xx:xx:xx:xx:xx"
profile "a2dp"
where the xās are yr target deviceās MAC address you found earlier.
Both of the above set the āinterfaceā option and that seems totally right to me, but for whatever reason, alsa didnāt like it, so I removed it. If you have more than one interface on pi somehow, I can see that being a problem, but I donāt, so w/e works.
The next step I did because Iām working with that snapcast plugin and that wonly build process had me modify it as well, so, cool. It shouldnāt be too difficult to figure out if that works for you, but Iām not a resource on that. Anyhoot, weāre gonna edit the mpd conf:
nano /etc/mpd.conf
and add the following to the āaudio outputā section:
audio_output {
type "alsa"
name "My swank bluetooth device name"
device "bluealsa"
Make sure you use bluetoothctl to pair, connect, and (probably) trust, and you may just have the ability to stream to yr device. No promises, sry. Iām pretty sure that all the steps are necessary even if one isnāt using snapcast, unless maybe you have some other non-standard set-up. Bon chance.
doesnāt work for me I just get:
ALSA lib conf.c:4858:(parse_args) Unknown parameter HCI
ALSA lib conf.c:4991:(snd_config_expand) Parse arguments error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa:HCI=hci0,DEV=88:C6:26:E9:5F:8B,PROFILE=a2dp
when testing with:
aplay -D bluealsa:HCI=hci0,DEV=88:C6:26:E9:5F:8B,PROFILE=a2dp ~/testfile.wav
iām new in this, i tried your example, but my question is. should i see something in alsa control panel? like the bt device? because i cannot hear anything.
Hello, I am using Volumio Virtuoso ABO. According to the description there should be Bluetooth included. But I cannot find the plugin. Do I have to install it separately? If necessary I can upload a log file.
I have Volumio running well.
Power = Triplite mpr 4.5 Precision Switching Power Supply 12 V 4.5 Amps
DC to DC Converter = USB QC3.0 QC2.0 DC-DC Buck Converter Charging Step Down Module 6-32V 9V 12V 24V to Fast Quick Charger Circuit Board 3V 5V 12V - 4CH Checked with meters, and USB passthrough, clean and smart but I have only tested 2.
Rpi 3 B with old 480GB SSD and MonoPrice SSD to 3.1 USB
HAT = HIFI DAC Audio Expansion Board PCM5122 Chip for Raspberry 3 Model B+/3B
Self Built Tube Preamp - I like the Tube sound
Into Yamaha Stereo R-7000
As you can see I am doing this as cheaply as possible. The one thing missing is Bluetooth so I can hear this on my Bluetooth Ear Pieces under my ear protection in the work area. I have too many hobbies to list. That is the beauty of being retired.
I have read a lot on the forums and need to resolve this.
THANK YOU ALL
Hat =
Iām having the same issue - I canāt enable the plugin (RPI 3B, no audio card just headphones jack). The log while enabling:
Jan 07 17:44:07 volumio volumio[984]: info: Enabling plugin bluetooth_controller
Jan 07 17:44:07 volumio volumio[984]: info: Loading plugin "bluetooth_controller"...
Jan 07 17:44:07 volumio volumio[984]: error: !!!! WARNING !!!!
Jan 07 17:44:07 volumio volumio[984]: error: The plugin audio_interface/bluetooth_controller failed to load, setting it to stopped. Error: Error: Cannot find module '/data/plugins/audio_interface/bluetooth_controller/node_modules/udev/build/node-v57-linux-arm/udev.node'
Jan 07 17:44:07 volumio volumio[984]: error: Stack trace: Error: Cannot find module '/data/plugins/audio_interface/bluetooth_controller/node_modules/udev/build/node-v57-linux-arm/udev.node'
Jan 07 17:44:07 volumio volumio[984]: at Function.Module._resolveFilename (module.js:547:15)
Jan 07 17:44:07 volumio volumio[984]: at Function.Module._load (module.js:474:25)
Jan 07 17:44:07 volumio volumio[984]: at Module.require (module.js:596:17)
Jan 07 17:44:07 volumio volumio[984]: at require (internal/module.js:11:18)
Jan 07 17:44:07 volumio volumio[984]: at Object.<anonymous> (/data/plugins/audio_interface/bluetooth_controller/node_modules/udev/udev.js:4:12)
Jan 07 17:44:07 volumio volumio[984]: at Module._compile (module.js:652:30)
Jan 07 17:44:07 volumio volumio[984]: at Object.Module._extensions..js (module.js:663:10)
Jan 07 17:44:07 volumio volumio[984]: at Module.load (module.js:565:32)
Jan 07 17:44:07 volumio volumio[984]: at tryModuleLoad (module.js:505:12)
Jan 07 17:44:07 volumio volumio[984]: at Function.Module._load (module.js:497:3)
Jan 07 17:44:07 volumio volumio[984]: at Object.<anonymous> (/data/plugins/audio_interface/bluetooth_controller/AVRCP.js:2:12)
Jan 07 17:44:07 volumio volumio[984]: info: Done.
