Bluetooth Airplay and HDMI port disable
Hallo to all!
Can someone write the steps I should follow to disable Bluetooth and airplay on RPi3?
Or a link to a thread about this if there is one!
Thank you very much in advance!
I don’t have a Volumio in front of me, but I believe adding the following two lines would do it for BT and/or WiFi (comment out the wifi line if you need WiFi):
nano /boot/config.txt
####Disable bluetooth and WiFi ####
dtoverlay=pi3-diable-bt
dtoverlay=pi3-diable-wifi
For HDMI, you need to type the following command after every boot:
sudo /opt/vc/bin/tvservice -o
Don’t know about Airplay. But, try this:
https://volumio.org/forum/airplay-password-disable-airplay-t719.html
Thank you very much!!!
I will try as soon as I can get ssh access!
I can not even though I have enabled it from VOLUMIOIP/DEV page!
Any help about my ssh problem?
Thnx!!
