In plugins management in the installed plugins tab select settings for the autostart plugin and try changing the Delay before music starts to 20000. Mine didn’t autostart after the update and I set it to 11000 and now it does. I have a raspberry pi 2.
Well not sure if this has been posted or raised earlier but as per my understanding the autoplay function should enable to song to play from where it was left before the player for shut off, once its turned ON it should start playing from where the track was left. However as per my experience it plays from the first track in the queue and not the track which was playing earlier. Is there a way around to make it play from where the track was last left to avoid the start of queue sequence. I am using Volumio over wifi with Digione Signature player.
