automount network drive
Hi!
I mount my linux smb network drive as local via ssh command - sudo mount -o username=bug00 //10.10.10.200/music/ /media/music - it’s work great, but i need auto mounting…
i try edit fstab - add string //10.10.10.200/music /media/music cifs auto,_netdev,user=bug00,pass=111111,noperm,wine,utf8 0 0
but after rebot that string missing, wtf?
Have Anyone a solution for automounting network samba shara?
Hi Bug
Add your shares in the volumio UI
“My music” -> “Add New Drive”
Via volumio UI my network drive not worked, i don’t know why
Is it an Windows share ?
try to add vers=2.1 or vers=2.0 as “Options”
It’s a linux samba server share
In what way does it not work when you attempt to mount it via the Volumio UI?
Today ain’t Unix/Linux my backyard !
But i’m using using a samba share on a Rpi “OMV” Nas without any options on the Volumio nor the OMV side (more than username and password)
What device and what version of Volumio are you using please?
For the connection to my Synology, I also had to add the vers parameter.
(I used vers=1.0, I will try to change to the higher values.)
