AUDIOPHONICS SABRE V3 Pulsante e Display
New Volumio LCD driver “16x2_oled_volumio_r2v2.py”.
Tested with AUDIOPHONICS RaspDAC I-Sabre V3 - Kit DIY Network player Raspberry Pi 3.0 & DAC
Bye
16x2_oled_volumio_r2v2.zip (3.66 KB)
This is not a driver, but a script to read the mpd status and print to an LCD screen.
Nonetheless, it looks good, so if you’re only using MPD as a player it should work for you.
Hello
I have an i-saber v4 and I have a question.
Does the display have to work also have a switched on / off switch?
I want to use this plugin:
github.com/JedS/Raspdac
I have the same need. Unfortunately the Raspdac 0.0.3 plugin doesn’t work on Volumio2.4x / 2.5x.!!!
We need to wait for a new version of Plugin… and Volumio team must validate it.
Bye
Are you looking for support for the button or also the LCD?
You can update the node packages I guess, that would make it work on newer versions.
Also, not to steal Jedails shine, I’ve downsized the plugin for button functionality only, see PR: audiophonics-onoff
The main delay is finding resources to check the code for various plugin uploads. To ensure stability and code quality a peer developer must validate the code submitted into the plugin store.
