AUDIOPHONICS DAC I-Sabre ES9038Q2M OLED Rotary Encoder
I consider to order this one just to find out their (secret) I2C address of the display.
Anyway if it differs from 3C there is not much to fix if it is hardcoded in their microprocessor.
There are also differences with different rotary encoders :slight_smile:
https://www.audiophonics.fr/en/selector-sources-module/input-selector-volume-control-board-with-screen-for-i-sabre-es9038q2m-p-15150.html
15150-module-source-volume-inpage1
Josef
I saw it, but i dont want to invest too much to find that it is hardcoded somewhere inside, i will survive without it.
Anyway it is something worth to find out i think. You made me “hot” for it.
I will ask them for support on that before i eventually buy it.
With a little soldering you could use Saiyato’s Rotary Encoder plugin and supercrab’s (+ Adrii) display plugin to make your devices work.
Yes, but hard to say which pins i can use.
For the display it is easy - use GPIO2 and GPIO3 (PIN 3 and 5) for I2C
I also use the “cheap” display. It has I2C address 3C but supercrab’s plugin let’s you check for that.
The encoder - i can tell you on Saturday how i did it - i do not have the device here and unfortunately no docu on it, but it’s working very reliable with the 100nF capacitors in place like described on Saiyato’s github page.
You may also find this interesting:
Many thanks Josh, but i removed it all and will let it naked, i bought this for easy use and dont want torture myself with another tweaks, i have something better
Oh nice - sure an OLED display won’t fit that retro style :slight_smile:
But now i have new info from Audiophonics help, it is possible to use this another connector, but only for SPI displays.
Ed
Interesting - but what “another connector” do you mean ? - the 40PIN ?
I don’t see any SPI connector on the DAC board.
Did you also ask for the I2C address of their OLED displays ?
Josef
Yes, please see yellow frame in image, and another interesting thing, they write rotary encoder works only with OLED screen, not true it works pretty alone as well
Ed
See my first assembly
Can you explain what you did there…
Yes, this was assembly first version, Raspberry Pi + Audiophonics DAC I-Sabre + Audiophonics power module, then i added driver for analog VU meter. Also Audiophonics rotary encoder is visible.
In 2-nd version I replaced analog VU with 4" LCD driven by peppymeter, I also replaced rotary encoder with IR remote control. See image below
