In My Music, Artists, I do not see some thumbnails, that is, there are artists without images.
Is there any way to fix it?
Can I select by myself the image?
I see without problems the thumbnails of the albums.
regards
Give an example of tags.
I see that the images of Artists are saved in /Data/albumart/web inside the folder of each artist in png format.
I suppose he download them up from the web.
Artists that do not have an image do not have an associated PNG either.
Then it occurred to me to upload an image of the Artist in that folder but I still do not see it in “Artists”
Is there any consideration in terms of size, name, extension to be considered or does this method not work?
I got the same problem and also failed to solve it.
