Do you now see Volumio’s boot screen?
Please post the output of
cat /var/log/Xorg.0.log
once more.
once more.
[ 53.284]
X.Org X Server 1.20.4
[ 53.285] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 53.285] Current Operating System: Linux chazio 5.10.92-v7+ #1514 SMP Mon Ja n 17 17:36:39 GMT 2022 armv7l
[ 53.285] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.e nable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=320 bcm2708_fb. fbheight=240 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:E9:6F:95 vc_mem.mem_b ase=0x1ec00000 vc_mem.mem_size=0x20000000 splash plymouth.ignore-serial-console s dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg .nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 im gfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.gl obal_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa=0 snd_bcm2835 .enable_hdmi=1 loglevel=0
[ 53.285] Build Date: 04 April 2023 07:50:56AM
[ 53.285] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support )
[ 53.285] Current version of pixman: 0.36.0
[ 53.285] Before reporting problems, check http://wiki.x.org
[ 53.285] Markers: (--) probed, (**) from config file, (==) default setting,
[ 53.285] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 26 02:08:12 202 3
[ 53.302] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 53.302] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 53.315] (==) No Layout section. Using the first Screen section.
[ 53.315] (==) No screen section available. Using defaults.
[ 53.315] (**) |-->Screen "Default Screen Section" (0)
[ 53.315] (**) | |-->Monitor "<default monitor>"
[ 53.322] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 53.322] (**) | |-->Device "Allwinner A10/A13/A20 FBDEV"
[ 53.322] (==) No monitor specified for screen "Default Screen Section".
[ 53.322] (==) Automatically adding devices
[ 53.322] (==) Automatically enabling devices
[ 53.322] (==) Automatically adding GPU devices
[ 53.329] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 53.331] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 53.331] Entry deleted from font path.
[ 53.335] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 53.335] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 53.335] (II) The server relies on udev to provide the list of input devices .
If no devices become available, reconfigure udev or disable AutoAddDevic es.
[ 53.335] (II) Loader magic: 0x1fdf80
[ 53.335] (II) Module ABI versions:
[ 53.335] X.Org ANSI C Emulation: 0.4
[ 53.335] X.Org Video Driver: 24.0
[ 53.335] X.Org XInput driver : 24.1
[ 53.335] X.Org Server Extension : 10.0
[ 53.342] (--) using VT number 2
[ 53.342] (II) systemd-logind: logind integration requires -keeptty and -keep tty was not provided, disabling logind integration
[ 53.342] (II) no primary bus or device found
[ 53.342] (II) LoadModule: "glx"
[ 53.345] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 53.414] (II) Module glx: vendor="X.Org Foundation"
[ 53.414] compiled for 1.20.4, module version = 1.0.0
[ 53.414] ABI class: X.Org Server Extension, version 10.0
[ 53.414] (II) LoadModule: "fbturbo"
[ 53.415] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 53.419] (II) Module fbturbo: vendor="X.Org Foundation"
[ 53.419] compiled for 1.20.3, module version = 0.5.1
[ 53.419] Module class: X.Org Video Driver
[ 53.419] ABI class: X.Org Video Driver, version 24.0
[ 53.419] (II) FBTURBO: driver for framebuffer: fbturbo
[ 53.421] (WW) Falling back to old probe method for fbturbo
[ 53.421] (II) Loading sub module "fbdevhw"
[ 53.421] (II) LoadModule: "fbdevhw"
[ 53.421] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 53.424] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 53.424] compiled for 1.20.4, module version = 0.0.2
[ 53.424] ABI class: X.Org Video Driver, version 24.0
[ 53.424] (II) FBTURBO(0): using /dev/fb0
[ 53.424] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 53.425] (II) FBTURBO(0): Creating default Display subsection in Screen sect ion
[ 53.425] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[ 53.425] (==) FBTURBO(0): RGB weight 888
[ 53.425] (==) FBTURBO(0): Default visual is TrueColor
[ 53.425] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 53.425] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 300kB)
[ 53.425] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 53.425] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[ 53.425] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 53.425] (II) FBTURBO(0): processor: Unknown
[ 53.425] (II) FBTURBO(0): checking modes against framebuffer device...
[ 53.425] (II) FBTURBO(0): checking modes against monitor...
[ 53.425] (II) FBTURBO(0): Virtual size is 320x240 (pitch 320)
[ 53.425] (**) FBTURBO(0): Built-in mode "current"
[ 53.425] (==) FBTURBO(0): DPI set to (96, 96)
[ 53.425] (II) Loading sub module "fb"
[ 53.425] (II) LoadModule: "fb"
[ 53.426] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 53.432] (II) Module fb: vendor="X.Org Foundation"
[ 53.432] compiled for 1.20.4, module version = 1.0.0
[ 53.432] ABI class: X.Org ANSI C Emulation, version 0.4
[ 53.451] (II) FBTURBO(0): using backing store heuristics
[ 53.469] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[ 53.469] (II) FBTURBO(0): failed to enable the use of sunxi display controll er
[ 53.469] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp an d /dev/g2d)
[ 53.469] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[ 53.469] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[ 53.469] (==) FBTURBO(0): Backing store enabled
[ 53.482] (==) FBTURBO(0): DPMS enabled
[ 53.482] (II) FBTURBO(0): failed to enable hardware cursor
[ 53.482] (II) FBTURBO(0): no 3D acceleration because the driver has been com piled without libUMP
[ 53.482] (II) FBTURBO(0): if this is wrong and needs to be fixed, please che ck ./configure log
[ 53.483] (II) Initializing extension Generic Event Extension
[ 53.484] (II) Initializing extension SHAPE
[ 53.485] (II) Initializing extension MIT-SHM
[ 53.487] (II) Initializing extension XInputExtension
[ 53.494] (II) Initializing extension XTEST
[ 53.495] (II) Initializing extension BIG-REQUESTS
[ 53.497] (II) Initializing extension SYNC
[ 53.498] (II) Initializing extension XKEYBOARD
[ 53.499] (II) Initializing extension XC-MISC
[ 53.500] (II) Initializing extension SECURITY
[ 53.502] (II) Initializing extension XFIXES
[ 53.503] (II) Initializing extension RENDER
[ 53.504] (II) Initializing extension RANDR
[ 53.506] (II) Initializing extension COMPOSITE
[ 53.514] (II) Initializing extension DAMAGE
[ 53.515] (II) Initializing extension MIT-SCREEN-SAVER
[ 53.516] (II) Initializing extension DOUBLE-BUFFER
[ 53.517] (II) Initializing extension RECORD
[ 53.519] (II) Initializing extension DPMS
[ 53.520] (II) Initializing extension Present
[ 53.521] (II) Initializing extension DRI3
[ 53.521] (II) Initializing extension X-Resource
[ 53.522] (II) Initializing extension XVideo
[ 53.523] (II) Initializing extension XVideo-MotionCompensation
[ 53.523] (II) Initializing extension SELinux
[ 53.523] (II) SELinux: Disabled on system
[ 53.523] (II) Initializing extension GLX
[ 53.525] (II) AIGLX: Screen 0 is not DRI2 capable
[ 55.905] (II) IGLX: Loaded and initialized swrast
[ 55.905] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 55.905] (II) Initializing extension XFree86-VidModeExtension
[ 55.907] (II) Initializing extension XFree86-DGA
[ 55.908] (II) Initializing extension XFree86-DRI
[ 55.913] (II) Initializing extension DRI2
[ 56.280] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/even t1)
[ 56.280] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
[ 56.281] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall"
[ 56.281] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
[ 56.281] (II) LoadModule: "evdev"
[ 56.281] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 56.291] (II) Module evdev: vendor="X.Org Foundation"
[ 56.291] compiled for 1.20.3, module version = 2.10.6
[ 56.291] Module class: X.Org XInput Driver
[ 56.291] ABI class: X.Org XInput driver, version 24.1
[ 56.291] (II) Using input driver 'evdev' for 'gpio_ir_recv'
[ 56.291] (**) gpio_ir_recv: always reports core events
[ 56.291] (**) evdev: gpio_ir_recv: Device: "/dev/input/event1"
[ 56.291] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
[ 56.291] (--) evdev: gpio_ir_recv: Found relative axes
[ 56.291] (--) evdev: gpio_ir_recv: Found x and y relative axes
[ 56.291] (--) evdev: gpio_ir_recv: Found keys
[ 56.291] (II) evdev: gpio_ir_recv: Configuring as mouse
[ 56.291] (II) evdev: gpio_ir_recv: Configuring as keyboard
[ 56.291] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver@1 7/rc/rc0/input2/event1"
[ 56.291] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEY BOARD, id 6)
[ 56.291] (**) Option "xkb_rules" "evdev"
[ 56.291] (**) Option "xkb_model" "pc105"
[ 56.291] (**) Option "xkb_layout" "us"
[ 56.292] (II) evdev: gpio_ir_recv: initialized for relative axes.
[ 56.293] (**) gpio_ir_recv: (accel) keeping acceleration scheme 1
[ 56.293] (**) gpio_ir_recv: (accel) acceleration profile 0
[ 56.293] (**) gpio_ir_recv: (accel) acceleration factor: 2.000
[ 56.293] (**) gpio_ir_recv: (accel) acceleration threshold: 4
[ 56.297] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/event2)
[ 56.297] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen ca tchall"
[ 56.297] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[ 56.297] (**) ADS7846 Touchscreen: Applying InputClass "Touch rotation"
[ 56.297] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 56.297] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[ 56.297] (**) ADS7846 Touchscreen: always reports core events
[ 56.297] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event2"
[ 56.297] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[ 56.297] (--) evdev: ADS7846 Touchscreen: Found absolute axes
[ 56.297] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 56.297] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 56.297] (**) Option "SwapAxes" "1"
[ 56.297] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 56.297] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 56.297] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWhee lInertia: 10, EmulateWheelTimeout: 200
[ 56.298] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f204000. spi/spi_master/spi0/spi0.1/input/input3/event2"
[ 56.298] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (ty pe: TOUCHSCREEN, id 7)
[ 56.298] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 56.298] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 56.298] (**) ADS7846 Touchscreen: (accel) acceleration profile 0
[ 56.299] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 56.299] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 56.301] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/mouse0)
[ 56.301] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 56.301] (II) No input driver specified, ignoring this device.
[ 56.302] (II) This device may have been added with another device file.
[ 56.306] (II) config/udev: Adding input device Creative Technology Ltd Sound Blaster Play! 3 Consumer Control (/dev/input/event0)
[ 56.307] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : Applying InputClass "evdev keyboard catchall"
[ 56.307] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : Applying InputClass "libinput keyboard catchall"
[ 56.307] (II) Using input driver 'evdev' for 'Creative Technology Ltd Sound Blaster Play! 3 Consumer Control'
[ 56.307] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : always reports core events
[ 56.307] (**) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Device: "/dev/input/event0"
[ 56.307] (--) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Vendor 0x41e Product 0x324d
[ 56.307] (--) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Found relative axes
[ 56.307] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Forcing relative x/y axes to exist.
[ 56.307] (--) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Found keys
[ 56.307] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Configuring as mouse
[ 56.307] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Configuring as keyboard
[ 56.307] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000. usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:041E:324D.0001/input/input0/event0"
[ 56.307] (II) XINPUT: Adding extended input device "Creative Technology Ltd Sound Blaster Play! 3 Consumer Control" (type: KEYBOARD, id 8)
[ 56.307] (**) Option "xkb_rules" "evdev"
[ 56.307] (**) Option "xkb_model" "pc105"
[ 56.307] (**) Option "xkb_layout" "us"
[ 56.308] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: initialized for relative axes.
[ 56.309] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) keeping acceleration scheme 1
[ 56.309] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) acceleration profile 0
[ 56.309] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) acceleration factor: 2.000
[ 56.309] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) acceleration threshold: 4
/dev/fb1? instead of 0?
After boot, screen does change from white to black, no logo
If
ls -al /dev/fb*
now shows “fb1” yes.
Im changing it in file /usr/share/X11/xorg.conf.d/99-fbturbo.conf
Is this correct, or somewhere else to get desired change?
Am I correct in thinking the above should point to fb1, instead of 0 for display demarcation?
OOOOOOOKAYYY, after messing with 99–fbturbo.conf I have output to the screen, resolution is not correctit is stretched off the screen to the right so width is incorrect, what is the most simple way to change resolution?
Almost there! Thank you, Thank you again!
Yes, the initial value in “99-fbturbo.conf” was correct, just the name if the .dtbo file was wrong… I have corrected the post live in post #2.
Regarding resolution: Could you post a picture showing the display?
output now
[ 52.825]
[ 52.825] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 52.825] Current Operating System: Linux chazio 5.10.92-v7+ #1514 SMP Mon Ja n 17 17:36:39 GMT 2022 armv7l
[ 52.825] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.e nable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=320 bcm2708_fb. fbheight=240 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:E9:6F:95 vc_mem.mem_b ase=0x1ec00000 vc_mem.mem_size=0x20000000 splash plymouth.ignore-serial-console s dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg .nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 im gfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.gl obal_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa=0 snd_bcm2835 .enable_hdmi=1 loglevel=0
[ 52.825] Build Date: 04 April 2023 07:50:56AM
[ 52.825] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support )
[ 52.825] Current version of pixman: 0.36.0
[ 52.825] Before reporting problems, check http://wiki.x.org
[ 52.825] Markers: (--) probed, (**) from config file, (==) default setting,
[ 52.826] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 26 07:53:23 202 3
[ 52.849] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 52.849] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 52.871] (==) No Layout section. Using the first Screen section.
[ 52.871] (==) No screen section available. Using defaults.
[ 52.871] (**) |-->Screen "Default Screen Section" (0)
[ 52.871] (**) | |-->Monitor "<default monitor>"
[ 52.878] (==) No device specified for screen "Default Screen Section".
[ 52.878] (**) | |-->Device "Allwinner A10/A13/A20 FBDEV"
[ 52.878] (==) No monitor specified for screen "Default Screen Section".
[ 52.878] (==) Automatically adding devices
[ 52.878] (==) Automatically enabling devices
[ 52.878] (==) Automatically adding GPU devices
[ 52.885] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 52.886] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 52.887] Entry deleted from font path.
[ 52.889] (==) FontPath set to:
built-ins
[ 52.889] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 52.889] (II) The server relies on udev to provide the list of input devices .
[ 52.889] (II) Loader magic: 0x1fdf80
[ 52.889] (II) Module ABI versions:
[ 52.889] X.Org ANSI C Emulation: 0.4
[ 52.889] X.Org Video Driver: 24.0
[ 52.889] X.Org XInput driver : 24.1
[ 52.889] X.Org Server Extension : 10.0
[ 52.892] (--) using VT number 2
[ 52.892] (II) systemd-logind: logind integration requires -keeptty and -keep tty was not provided, disabling logind integration
[ 52.892] (II) no primary bus or device found
[ 52.892] (II) LoadModule: "glx"
[ 52.897] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 52.958] (II) Module glx: vendor="X.Org Foundation"
[ 52.958] compiled for 1.20.4, module version = 1.0.0
[ 52.958] ABI class: X.Org Server Extension, version 10.0
[ 52.958] (II) LoadModule: "fbturbo"
[ 52.960] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 52.964] (II) Module fbturbo: vendor="X.Org Foundation"
[ 52.964] compiled for 1.20.3, module version = 0.5.1
[ 52.964] Module class: X.Org Video Driver
[ 52.964] ABI class: X.Org Video Driver, version 24.0
[ 52.964] (II) FBTURBO: driver for framebuffer: fbturbo
[ 52.966] (WW) Falling back to old probe method for fbturbo
[ 52.966] (II) Loading sub module "fbdevhw"
[ 52.966] (II) LoadModule: "fbdevhw"
[ 52.966] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 52.968] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 52.968] compiled for 1.20.4, module version = 0.0.2
[ 52.968] ABI class: X.Org Video Driver, version 24.0
[ 52.969] (II) FBTURBO(0): using /dev/fb1
[ 52.969] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 52.969] (II) FBTURBO(0): Creating default Display subsection in Screen sect ion
"Default Screen Section" for depth/fbbpp 16/16
[ 52.969] (==) FBTURBO(0): Depth 16, (==) framebuffer bpp 16
[ 52.969] (==) FBTURBO(0): RGB weight 565
[ 52.969] (==) FBTURBO(0): Default visual is TrueColor
[ 52.969] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 52.969] (II) FBTURBO(0): hardware: fb_ili9340 (video memory: 150kB)
[ 52.969] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 52.969] (**) FBTURBO(0): Option "fbdev" "/dev/fb1"
[ 52.969] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 52.969] (II) FBTURBO(0): processor: Unknown
[ 52.969] (II) FBTURBO(0): checking modes against framebuffer device...
[ 52.969] (II) FBTURBO(0): checking modes against monitor...
[ 52.970] (II) FBTURBO(0): Virtual size is 320x240 (pitch 320)
[ 52.970] (**) FBTURBO(0): Built-in mode "current"
[ 52.970] (==) FBTURBO(0): DPI set to (96, 96)
[ 52.970] (II) Loading sub module "fb"
[ 52.970] (II) LoadModule: "fb"
[ 52.971] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 52.976] (II) Module fb: vendor="X.Org Foundation"
[ 52.976] compiled for 1.20.4, module version = 1.0.0
[ 52.976] ABI class: X.Org ANSI C Emulation, version 0.4
[ 52.977] (II) FBTURBO(0): FBIOBLANK: Invalid argument (Screen blanking not s upported by kernel - disabling)
[ 52.995] (II) FBTURBO(0): using backing store heuristics
[ 53.010] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[ 53.010] (II) FBTURBO(0): failed to enable the use of sunxi display controll er
[ 53.010] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp an d /dev/g2d)
[ 53.010] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[ 53.010] (II) FBTURBO(0): enabled VFP/NEON optimizations
[ 53.010] (==) FBTURBO(0): Backing store enabled
[ 53.018] (==) FBTURBO(0): DPMS enabled
[ 53.018] (II) FBTURBO(0): failed to enable hardware cursor
[ 53.018] (II) FBTURBO(0): no 3D acceleration because the driver has been com piled without libUMP
[ 53.018] (II) FBTURBO(0): if this is wrong and needs to be fixed, please che ck ./configure log
[ 53.020] (II) Initializing extension Generic Event Extension
[ 53.021] (II) Initializing extension SHAPE
[ 53.022] (II) Initializing extension MIT-SHM
[ 53.023] (II) Initializing extension XInputExtension
[ 53.028] (II) Initializing extension XTEST
[ 53.029] (II) Initializing extension BIG-REQUESTS
[ 53.030] (II) Initializing extension SYNC
[ 53.031] (II) Initializing extension XKEYBOARD
[ 53.032] (II) Initializing extension XC-MISC
[ 53.033] (II) Initializing extension SECURITY
[ 53.034] (II) Initializing extension XFIXES
[ 53.035] (II) Initializing extension RENDER
[ 53.037] (II) Initializing extension RANDR
[ 53.039] (II) Initializing extension COMPOSITE
[ 53.041] (II) Initializing extension DAMAGE
[ 53.042] (II) Initializing extension MIT-SCREEN-SAVER
[ 53.043] (II) Initializing extension DOUBLE-BUFFER
[ 53.044] (II) Initializing extension RECORD
[ 53.045] (II) Initializing extension DPMS
[ 53.046] (II) Initializing extension Present
[ 53.047] (II) Initializing extension DRI3
[ 53.048] (II) Initializing extension X-Resource
[ 53.049] (II) Initializing extension XVideo
[ 53.050] (II) Initializing extension XVideo-MotionCompensation
[ 53.050] (II) Initializing extension SELinux
[ 53.050] (II) SELinux: Disabled on system
[ 53.050] (II) Initializing extension GLX
[ 53.051] (II) AIGLX: Screen 0 is not DRI2 capable
[ 54.517] (II) IGLX: Loaded and initialized swrast
[ 54.518] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 54.518] (II) Initializing extension XFree86-VidModeExtension
[ 54.519] (II) Initializing extension XFree86-DGA
[ 54.520] (II) Initializing extension XFree86-DRI
[ 54.523] (II) Initializing extension DRI2
[ 55.007] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/even t1)
[ 55.007] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
[ 55.007] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall"
[ 55.007] (II) LoadModule: "evdev"
[ 55.007] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 55.028] (II) Module evdev: vendor="X.Org Foundation"
[ 55.028] compiled for 1.20.3, module version = 2.10.6
[ 55.028] Module class: X.Org XInput Driver
[ 55.028] ABI class: X.Org XInput driver, version 24.1
[ 55.028] (II) Using input driver 'evdev' for 'gpio_ir_recv'
[ 55.028] (**) gpio_ir_recv: always reports core events
[ 55.029] (**) evdev: gpio_ir_recv: Device: "/dev/input/event1"
[ 55.029] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
[ 55.029] (--) evdev: gpio_ir_recv: Found relative axes
[ 55.029] (--) evdev: gpio_ir_recv: Found x and y relative axes
[ 55.029] (--) evdev: gpio_ir_recv: Found keys
[ 55.029] (II) evdev: gpio_ir_recv: Configuring as mouse
[ 55.029] (II) evdev: gpio_ir_recv: Configuring as keyboard
[ 55.029] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver@1 7/rc/rc0/input2/event1"
[ 55.029] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEY BOARD, id 6)
[ 55.029] (**) Option "xkb_rules" "evdev"
[ 55.029] (**) Option "xkb_model" "pc105"
[ 55.029] (**) Option "xkb_layout" "us"
[ 55.030] (II) evdev: gpio_ir_recv: initialized for relative axes.
[ 55.031] (**) gpio_ir_recv: (accel) keeping acceleration scheme 1
[ 55.031] (**) gpio_ir_recv: (accel) acceleration profile 0
[ 55.031] (**) gpio_ir_recv: (accel) acceleration factor: 2.000
[ 55.031] (**) gpio_ir_recv: (accel) acceleration threshold: 4
[ 55.035] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/event2)
[ 55.035] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen ca tchall"
[ 55.035] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[ 55.035] (**) ADS7846 Touchscreen: Applying InputClass "Touch rotation"
[ 55.035] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 55.035] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[ 55.035] (**) ADS7846 Touchscreen: always reports core events
[ 55.035] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event2"
[ 55.035] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[ 55.035] (--) evdev: ADS7846 Touchscreen: Found absolute axes
[ 55.036] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 55.036] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 55.036] (**) Option "SwapAxes" "1"
[ 55.036] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 55.036] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 55.036] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWhee lInertia: 10, EmulateWheelTimeout: 200
[ 55.036] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f204000. spi/spi_master/spi0/spi0.1/input/input3/event2"
[ 55.036] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (ty pe: TOUCHSCREEN, id 7)
[ 55.036] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 55.037] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 55.037] (**) ADS7846 Touchscreen: (accel) acceleration profile 0
[ 55.037] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 55.037] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 55.040] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/mouse0)
[ 55.040] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 55.040] (II) No input driver specified, ignoring this device.
[ 55.040] (II) This device may have been added with another device file.
[ 55.045] (II) config/udev: Adding input device Creative Technology Ltd Sound Blaster Play! 3 Consumer Control (/dev/input/event0)
[ 55.045] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : Applying InputClass "evdev keyboard catchall"
[ 55.046] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : Applying InputClass "libinput keyboard catchall"
[ 55.046] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : Applying InputClass "evdev keyboard catchall"
[ 55.046] (II) Using input driver 'evdev' for 'Creative Technology Ltd Sound Blaster Play! 3 Consumer Control'
[ 55.046] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : always reports core events
[ 55.046] (**) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Device: "/dev/input/event0"
[ 55.046] (--) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Vendor 0x41e Product 0x324d
[ 55.046] (--) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Found relative axes
[ 55.046] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Forcing relative x/y axes to exist.
[ 55.046] (--) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Found keys
[ 55.046] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Configuring as mouse
[ 55.046] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: Configuring as keyboard
[ 55.046] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000. usb/usb1/1-1/1-1.2/1-1.2:1.3/0003:041E:324D.0001/input/input0/event0"
[ 55.046] (II) XINPUT: Adding extended input device "Creative Technology Ltd Sound Blaster Play! 3 Consumer Control" (type: KEYBOARD, id 8)
[ 55.046] (**) Option "xkb_rules" "evdev"
[ 55.046] (**) Option "xkb_model" "pc105"
[ 55.046] (**) Option "xkb_layout" "us"
[ 55.047] (II) evdev: Creative Technology Ltd Sound Blaster Play! 3 Consumer Control: initialized for relative axes.
[ 55.048] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) keeping acceleration scheme 1
[ 55.048] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) acceleration profile 0
[ 55.048] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) acceleration factor: 2.000
[ 55.048] (**) Creative Technology Ltd Sound Blaster Play! 3 Consumer Control : (accel) acceleration threshold: 4
Went under touchscreen plugin, changed scale to 50, it fits perfect, and touch working.
Next I’ll play around with Kiosk, to try to get art bigger/no controls, etc.
Thank you for all your help.
I have been looking, where is the correct place to add text for rotating the display, the plugin control does nothing, and I have been looking for the correct file to edit.
Thank you again.
With the values from post #2 display and touch are rotated by 270 deg. For rotating by 0, 90 or 180 deg. adapt the line
dtoverlay=tft9341:rotate=270
in “/boot/userconfig.txt” accordingly.
You will also have to change the values for Option "Calibration"
and Option "SwapAxes"
in “/etc/X11/xorg.conf.d/99-calibration.conf”. They should be as follows for a rotation by
Option "Calibration" "155 3865 115 3700"
Option "SwapAxes" "0"
Option "Calibration" "3700 115 155 3865"
Option "Calibration" "3865 155 3700 115"
