Today I tried again several times, a small improvement had set in for me, without me having changed anything… If I only use HIFI albums… so don’t switch from master to hifi… stream on Tidal and only start via the album cover and keep my fingers off the streamer with a bit of luck I can listen to an entire album. But as soon as I choose an album in master quality, it’s over.
But… when I connect to Volumio via Tidal Connect, everything works perfectly, even in master quality.
Via Connect, the E30 DAC correctly displays the Khz again… 44.1 and 48.0 (I still don’t quite understand… my GT5 shows green… should be 88.x for the album…Cliff Martinez The Wild,Season 2) Yesterday it was jumping wildly on the screen as if Volumio would resist going over 44.1. At the Dac it remained on 44.1…I personally have the suspicion that here where the dog is buried.
We worked a lot since the issue was reported on Thursday to identify the root cause and fix it.
This is an issue which is affecting the ingress of our Cloud Kubernetes cluster (which aggregates TIDAL and QOBUZ data). Unfortunately, we were not able to identify yet the root cause (which seems related to our provider infrastructure).
So, as a temporary measure, we have executed a backup plan which involved setting up a fallback infrastructure to manage QOBUZ and TIDAL browsing. So, situation is now back to normal.
Sorry for the inconvenience, but as always, you can trust that the Volumio team will do whatever to solve any issue as quickly as we can. We can’t stop listening music for silly Kubernetes glitches
Hello everyone, I’m new here in the group.
I also have the problem with Qobuz and sometimes with Tidal too. The system runs stably and suddenly it becomes totally slow or produces annoying noises. However, radio or Spotify are running. And later the system starts to spin and jumps through the titles by itself.
I use an RPi 4 with 2GB RAM with Allo Boss2 and a 5 inch DSI screen. Maybe someone has similar trouble. Greetings Marc
Great sausage guys!
It’s back since the update to 3.429. Volumio fails to play through a longer movement of a Qobuz opera or symphony. When playing individually, Volumio jumps to the “start screen”, when playing a playlist it jumps to the next sentence. People are said to have been killed for destroying Mahler’s 2nd. Be careful, I’ll probably be in Florence in April. Guys try hard, shit on colored screen and fun stuff. Please stay with a stable system.
Give it your all, thanks in advance, Dirk
