Alsa After online upgrade from version 2.691 issue
Hi all Volumio funs!
I’m using Volumio since more than one year.
After last update I got issue, there is no sound from my device RPi3 + HiFiBerry AMP2.
There was error: “Failed to open Alsa device hw:1,0.”
I was then check the output and DAC model - it is on the HifiBerryAmp (the AMP2 is missing), the Mixer type: software, but still no sound.
The sound is only then active (and it play quite loud) if I set the device in fully “factory reset” mode - but then it was play only in hardware mode - and can’t change the sound volume - after change the configuration to Software - there is stop come the sound.
Any suggestion?
Thank’s in advance
