This week, its a matter of days…
Hi, thanks for the new version 2.114 of Volumio.
My player is a Vana Player. Today I updated to version 2.114 of Volumio. After configuring the DAC Allo Piano 2.1 in setup I can not hear the music. In Playback section the media is played but there is no output sound in Volt amplifier. I tested it in all modes 2.0, 2.1 and 2.2. The DAC does not output sound by RCAs either.
I re-installed the previous version 2.041 to be able to hear music. Although I would like to have the new version …
Thank you very much!
Vana player? That works with Sparky doesn’t it?
Version 2.041 and 2.114 are for RPi.
Sorry, my configuration is pi3 + kali + Piano 2.1 + Volt (Vana Player with pi3). Version 2.041 works correctly. In 2.114 no sound out by Volt.
If you want to use 2.114 you may find that using the IQAudio DAC+ setting will work, but only in 2.0 mode.
Thank you, I try it tonight. I hope the problem is fixed in other versions.
Hi
Checked the Allo website and cannot see the instructions for connecting a pot to the Volt amp? Are they available yet?
Paul
any one tried as per the below link
github.com/sparkysbc/sparky_lin … CONFIG.pdf
I have tried and working.
Hi Paul ,
instructions will be available this week on allo website (on the stepped attenuator page)
are there any news on the software issues? Problem resolved with volumio 2.129?
I am not aware of any bugs/problems. Everything should work .
@Allo
With the Vana player, I was wondering if the next version of volumio with dual mono mode will work or is a improvement with the volt amp ?
Hi
we will build make in image available with the dual mono sometimes next week (Monday is off)
Sparky image :
To select double stereo : select 2.0 mode
drive.google.com/open?id=0BwRHg … jBUMzBCOVE
Enjoy.
Sparky image :
drive.google.com/open?id=0BwRHg … jBUMzBCOVEEnjoy.
Thank you very much, so in effect this means i can send the audio to two amps ?
I have a stereo amp which is currently getting the output from the Sparky piano2.1
so could i send the second RCA to another Receiver ? I want to see the difference it makes in the sound
Btw thank you to Allo and Volumio my music is sounding so much better, appreciate the hard work.
Yeap . Piano 2.1 becomes a “double stereo”
Do we need to add the Piano2.1 changes to our repo?
Done today
Hi, I just seen the Volumio build for RPi was just released,
any chance a sparky build will be released. ?
Also do you guys have a donate page i am loving the sound of my music with the Volumio and the Sparky etc build, would want to share my happiness.
We are working on it
