Allo Usbridge - No audio to DAC
I have just received a new Allo USBridge with pre installed Volumio. It connects fine to my network, has found my DAC (Music Fidelity V90) and have loaded my music on a usb drive. Everything appears to be setup and working, but No sound. What do I need to do. The software is latest version.
I have the same problem. I installed the last available version of Volumio on a USBridge (Sparky + Volumio) and there is no sound on my Benchmark DAC1 USB. The DAC plays perfectly well with Volumio on DigiOne player (via SPDIF) as well as with Jriver (via USB). Volumio sees Benchmark in its Audio setup but the DAC does not produce any sound.
Can someone help?
Do you have the volume turned up in Volumio? I only ask because that is what happened to me when I first connected it and did not get any sound.
That is most likely not the issue, I assume, but just wanted to point it out. Sometimes it is possible to overlook something.
