[allo sparky]Cannot install volumio
I just got a allo sparky and want to install volumio to it but after i flashed the img into the flash drive and pluged it into the device nothing happened and i dont even know if i have installed the system correctly.I tried to access to volumio.local but failed.Is there any way for me to solve this probem?Thank you!BTW can i using the device without installing the system just plug in the flash drive or SD CARD containing the music file? thank you
Check the md5 sum of your image, check that your sd card is ok, and have a look at the link in my signature for the “quick start guide.” Volumio.local doesn’t necessarily work, depending on the OS you are using.
sir thanks for your advice but after i plugged in the sd card nothing happened,Is there a way to know if the installation is going on?thank you!
If i want to reset the system what can i do?
Are there any leds showing on the sparky board? Did you try a different sd card? It’s very difficult to help without more detail :wink:
there’s only a blue led light,I tried 2 different sd card and a flash drive but nothing happened :frowning:
i saw someone said that wait for 6mins or more for the installation of the system but still the same and could not login to volumio:local :frowning:
I’m wondering if you have a faulty device. Please try to flash a standard Raspbian image to check if the board is working or not.
Edit: sorry for that, my mind was obviously NOT working properly :frowning: To check the device is working ok, you could flash one of allo’s other images.
Even thought it’s a allo sparky i still flash a standard Paspbian image?I will have a try!Thank you!
Can this image help me to fix the device or the image can only test out if the board is working or not?again thank you
Dear sir i have installed the system due to your help!
But a new problem just come up,I tried to play a music but an error just kept popping out
the error is ‘Error. Failed to open “Alsa” [Alsa]; Failed to open ALSA device “hw:1,0”: No such file or directory.’
I just searched on the internet and tried some ways out but did not work for me
what should i do? Thank you!
any help plz?
OK, so you now have a working Volumio that you can access the UI, correct? Are you using a DAC? Please give as much detail as possible, since we can’t “see” what you are trying to use :wink:
Edit: it appears that you have opened another thread for your alsa problem … that is fine, but please don’t continue this thread asking the same question.
Ys i can assess the UI now thx!
I am so sorry for opening another thread
I am using allo sparky+piano2.1 as a dac. Thank you!
