After installing a clean version of Linux, Volumio does not work
Hello. I installed a clean Linux system on the second raspberry. Now I wanted to install Volumio. I get the same screen every time. So it comes to the point where it asks for the Volumio login and password. The IP does not change. The raspberry hangs on this screen, even though I enter the password and ligin Volumio reaches the command line and so on. I changed the memory card - no change. I installed clean Linux and it starts correctly? What else can I do ? I would like to point out that the Volumio logo and the login/password screen appear for a moment. And that’s it?
  • Perform a clean flash of Volumio to the SD
  • Connect the rPi to a cabled network
  • Boot the rPi
  • When you see the login prompt:
  • Take a browser and navigate to http://volumio.local
  • Or use the iOs or Android app to complete the setup.
Thank you . It worked
Glad to sort this out!
Enjoy the magic :slight_smile:
