Hi
Would like to be able to define a route option somewhere in GUI, eg
" route add -net 192.168.20.0 netmask 255.255.255.0 gw 192.168.10.2 "
this way I can mount ( cifs/nfs ) to my library over VPN,
please remove this topic
thanks!
Hi
thanks!
This is really an edge case, so I don’t think we will add such option…
hi, is there a file available where you can add manual tasks, eg " route add -net 192.168.20.0 netmask 255.255.255.0 gw 192.168.10.2 "?
This file will be read at the end of boot cycle, once all other files have been loaded. thanks for thinking along with me
OK after resolving dependency problems (systemd) I installed cron and created a job which reads a script every minute checking if destination can(not) be reached
