Well I’m glad that you solved it. There are a number of posts on the forums at the moment, which I think are probably also permissions problems with the NAS rather than volumio.
I got mine working as well thanks to this thread!
In my case what resolved the issue was using the name of the Synology station in capitals (BLUFFDALE in my case) instead of the IP address…
now waiting for the library to load… any idea how long this might take?
Hey there,
i’ve stumbled upon this thread and it seemed to be a good idea. I got my Volumio mounted, but i’m not sure, what exactly was the mistake i’ve made, if it was the missing reboot of the synology or the allowance of non privileged ports. Changing the settings for non privileged ports to ‘allowed’ made it finally work.
Funfact, the NAS seems to be mounted, Volumio has found 640GB on it, but it doesn’t read them into my library…
thanks so far!
