Add in addition of my hifi speakers a bluetooth speaker
I have a raspberry 3B+(with VOLUMIO), a card hifiberry digi+ , an official screen 7" . All is connected to my preamp Rotel and it’s works fine…
Sometimes I want listen music or radio on the kitchen by example, how can I add a speaker bluetooth ?
Many thanks by advance…
Same problem for me, When I used the Pi jack out it was no problem, Just split the output and added one of those bluetooth dongles you can get on a well known auction site, However now I use a Boss DAC that’s no longer an option. If it was possible to output from DAC and analogue simultaneously it would allow a lot of flexibility including bluetooth connection and use in different rooms (although probably not at the same time because of sync issues).
