I am building a media player based on the new version of Volumio, a RaspberryPi 3 and the ATX Raspi PCs. When I type the required text to gain access to the githubusercontent it acknowledges connection then displays the following lines of text:
Gnu TLS: A TLS fatal alert has been received.
Gnu TLS: received alert: Close notify
Unable to establish SSL connection.
It does this repeatedly
Does anyone have any ides why the connection cannot be maintained.
Incidentally I did not have the same problem when building a similar set-up with the first version of Volumio and a RaspberryPi 2
Any assistance would be gratefully received thank you
I am trying to access the GitHub typing in a path which will install code to enable a Low Power Labs ATX power button to function. On every attempt it displays the 3 lines of text quoted in my first post.
Moving on… I have typed in the text you suggested both with and without the quotation marks and also changing 2006 to 2016 all to no avail. It displays Try ‘date --help’
By the way I think you new Volumio is fantastic. The first was good but you have managed to address so many little niggles
I read on a RPi forum that this issue could be a known conflict between my ISP server, Virgin Media, and the GitHub server. I took it to work, not Virgin, and connected to GitHub no problem.
I have another issue which I will explain in a new post
