Hi ,
Would you pls check the radio stațion from Volumio selection , for ex ;absolute radio is not working
Volumio latest stable version : 3.396
Working here in UK
Thanks, but I guess that @volumio should maintain this list or am I wrong.
a lot of uk streams are blocked and the list is pretty long.
and checking all streams and renewing them is a lot of work
Ok. Understood . Thanks
Btw , how do you find the stream url ?
just searching online for a other stream and picking it out of the html page of the site.
if you need one just ask i will help to find it.
For example , how do you extract the stream urls from Absolut radio …de
Thanks . Perfect
https://edge10.live-sm.absolutradio.de/absolut-hot
https://edge10.live-sm.absolutradio.de/absolut-bella
https://edge10.live-sm.absolutradio.de/absolut-top
https://edge10.live-sm.absolutradio.de/absolut-germany
https://edge10.live-sm.absolutradio.de/absolut-OLDIECLASSICS
https://edge10.live-sm.absolutradio.de/absolut-christmastime
https://edge02.live-sm.absolutradio.de/absolut-special/stream/mp3?maxvbr=3&aggregator=Radioplayer&=&&___cb=70744110397153
https://absolut-radio-coffeemusic.live-aacp.absolutradio.de?=&&___cb=538820821883029
https://absolut-radio-chillout.live-aacp.absolutradio.de?=&&___cb=681889393018316
