We have tested with many cards from the market. The main problem is that everyone implements i2s termination resistors differently .
So we can guarantee that it works fine with Boss player at 192Khz (or at 384Khz on our slave Kali/Pianos) but some cards have the wrong resistors (too high of a value) on the i2s. While it works on a RPI , the isolator was designed using the oscilloscope and we tweaked the R value until we get a perfect i2s signal.
This i2s signal creates problem if you have the wrong resistors on the card.
Can the isolator be used on car since the carâs DC voltage when running is around 14v.
And whether any improvement when using isolator on car can be seen since all the ground (-) on car is the same for all source of power (not using the battery pack?
because I had no space to build it in with the raspberry pi, is this my solution to provide the allo isolator with battery power.
I have used the battery of an old Bosch screw drill and built a box for it, including an on and off switch and LED, a digital screen showing the battery perentage, I will also build in it.
I charge with the original charger and it takes about three kwatier to go from empty to completely full and then it is a matter of putting it in the box and the allo iasolator is ready for use.
I know this topic is kind of old but, if you guys are so excited about using the battery pack for isolator, then why donât you just pull the power jumper on Boss, which should effectively isolate power flow between Boss and RPi and then power your Boss with the battery pack? There should be no need for the isolator.
tried all kinds of options, itâs not much but for me it still sounds best with allo boss jumper off and 12 volt battery isolator.
also a fun fact, the 12 volt battery only needs to be charged once a week.
