Hi everyone, since I updated Volumio 3 the screen doesn´t work. How can I install it? Any suggestion?
Thnaks a lot.
you installed the touch display plugin?
if yes you need to provide your hardware details.
which rPi
Which display
Sorry. Raspberry pi 3b and Waveshare 5 inch display.
And the touch display plugin is installed
Then go to the Waveshare site, look in the wiki for your display. As most likely you need to add some additional settings to the /boot/userconfig.txt file
Ok. Thank you very much
