Dr. Google is your best friend…
Section “InputClass”
Identifier “SwapXY”
Option “TransformationMatrix” “0 1 0 -1 0 1 0 0 1”
MatchIsTouchscreen “on”
EndSection
Ok, that ("0 1 0 -1 0 1 0 0 1”) would be the transformation matrix for a touch rotation by 90 deg. If that works for you, you can delete the file “99-swapxy.conf” and simply set the rotation value on the config page of the plugin to 90 deg.
New user, wasn’t allowed to send a replay in 20 hours
For now I leave it like this
Thanks for your support!!! Hope others can use it…
Hi @gvolt
I’m trying to get 3.5 inch GPIO display to work with RPi4 with Volumio 3 but no success. Appreciate some pointers and guidance. I do apologise in advance if it’s not appropriate to reply via this thread.
My display is this
I have followed a few forum thread
https://community.volumio.com/t/volumio-with-3-5-tft-touch-screen-gpio-rpi-3b/11265/183
https://community.volumio.com/t/resolved-buster-3-beta-3-5-inch-touchscreen-problem-error/47527
and of course this one too
Thank you
Regards
Kian Lee
Please post the results of
ls -al /usr/share/X11/xorg.conf.d
cat /var/log/Xorg.0.log
cat /boot/config.txt
cat /boot/userconfig.txt
Thank you for your response. ![]()
volumio@volumio:~$ ls -al /usr/share/X11/xorg.conf.d
total 14
drwxr-xr-x 2 root root 1024 Jan 16 08:01 .
drwxr-xr-x 1 root root 1024 Jan 16 07:02 …
-rw-r–r-- 1 root root 92 Feb 7 2019 10-amdgpu.conf
-rw-r–r-- 1 root root 1350 Apr 19 2021 10-quirks.conf
-rw-r–r-- 1 root root 92 Apr 6 2019 10-radeon.conf
-rw-r–r-- 1 root root 1429 Mar 31 2019 40-libinput.conf
-rw-r–r-- 1 root root 2747 Jun 26 2017 70-wacom.conf
-rw-r–r-- 1 root root 609 Jan 16 07:45 99-fbturbo.conf
volumio@volumio:~$ cat /var/log/Xorg.0.log
cat: /var/log/Xorg.0.log: No such file or directory
volumio@volumio:~$ cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
dtoverlay=tft35a:rotate=270
include userconfig.txt
volumio@volumio:~$ cat /boot/userconfig.txt
dtparam=spi=on
dtoverlay=tft35a
You should remove the dtoverlay setting from “/boot/config.txt” so it is present only in “/boot/userconfig.txt”.
But that is not the reason for your problem: I guess during the installation of the Touch Display plugin not all required software packages have been downloaded/installed properly.
Did you wait several minutes after the first boot so the data partition could fully expand? On a system where the data partition had not been expended there is typically not enough space for all the software the Touch Display plugin needs.
If you are sure your system is not lacking disk space, I recommend to uninstall the plugin.
Then enable “Plugins Test Mode” on //volumio.local/dev and re-install beta version 3.3.3 of the plugin.
This version of the plugin aborts (and rolls back) the plugin’s installation process if downloading/installing of one of the required software packages (xorg, chromium etc.) fails. Unlike version 3.3.1, now the plugin would not even appear in the list of installed plugins if a software download should have failed.
So, if you do not find the plugin in the list of installed plugins after the installation process has finished, it is because an error occurred during its installation. Maybe check your internet connection (especially for DNS problems) and try to install the plugin again.
I did a fresh install of volumio3, waited as advised and enabled plugin test mode in volumio.local/dev.
Installed touch display plugin 3.3.3, once completed it showed in installed plugin as touch display 3.3.1.
Should I proceed installing the display driver?
@gvolt
Got the display working with your advise and instructions. Many thanks ![]()
Thank you it works for me too with volumio 3.198
My LCD is in landscape with hdmi port at the bottom.
What I’ve done :
Installed “Touch Display Plugin” (I tried to install 3.3.3 but it seems that 3.3.1 is finally installed
(Activating temporarily “show mouse pointer” in this plugin is useful to calibrate your touch screen).
wget https://github.com/goodtft/LCD-show/raw/master/usr/tft35a-overlay.dtb
sudo cp tft35a-overlay.dtb /boot/overlays/tft35a.dtbo
nano /boot/userconfig.txt
#==== Put this in this file : ====
dtparam=spi=on
dtoverlay=tft35a:rotate=90
wget https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-calibration.conf-35-0
sudo cp 99-calibration.conf-35-0 /etc/X11/xorg.conf.d/99-calibration.conf
sudo wget https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-fbturbo.conf -P /usr/share/X11/xorg.conf.d
sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf
#and change
Driver "fbturbo"
#to
Driver "fbdev"
# To rotate de touch input (landscape with hdmi at the bottom)
sudo nano /etc/X11/xorg.conf.d/99-swapxy.conf
Section "InputClass"
Identifier "SwapXY"
Option "TransformationMatrix" "0 -1 1 1 0 0 0 0 1"
MatchIsTouchscreen "on"
EndSection
Installing “Now Playing” and in settings click on “Volumio Kiosk” offers a better view for a little 3.5 inch LCD !
