24bit files can't be played after upgrade from 2.411 onwards
Hi after upgrade to 2.411 e than 2.413 it’s impossible play file at 24 bit. I have a rpi with allo kali and piano dac. The most frustrating thing is the loss of all the playlists because the backup plugin does not create any files on the nas connected via samba. Needless to say, I’ve tried everything, I have to downgrade to 2.389.
Are you sure that this is not this issue with the current RPi kernel? Also here.
it could be but with the 2.389 it works and the kernel is the old one. I’ll try to turn on audio resampling, and set bitdepth to either 16 or 32 bits but the sound quality?
Sounds quality will be the same. Upsampling jis adding zeroes only.
OK now work fine, turning on resampling and 32bits
