2.389 upgrade no longer plays 24 bit FLAC's
I just upgraded to 2.389 on Raspberry Pi with an Allo 2.1 DAC, and my 24 bit FLAC files now produce only white noise. 16 bit files seem to be fine.
The system is set up for Dual-Stereo and DSD Direct…
Anyone else experiencing this? Or have thoughts on how to resolve?
Yeah your not alone. There’s two other posts… (I didn’t see the first one) The Boss driver works 24 bit but you’ll only get one set of outputs.
I also run the Raspberry Pi3 + Allo Kali + Allo Piano 2.1 combination and get a white noise when I play a 96/24 FLAC file.
Do you know why it doesn’t work or if a fix is on the way?
