Power failure a couple of days ago killed one of my Volumios. mSD card doesn’t mount at all – added to my growing pile of dead cards. (they sure seem to be fragile) Reloaded the iso and everything looks to be working, but I’m getting no sound from the Kali/Piano again. Any suggestions for a setting, tip, or tweak I’ve forgotten?
NAS mounts and scans. Queue works. Claims to be playing. The display shows play progress in song…
Have the same setup as you and everything works perfectly. Have you switched on i2S dac under ‘settings/play back options’ and selected Piano 2.1 as Output Device and DAC?
Yes. Except I don’t have the 2.1. Just the regular Piano. I’ve switched it to piano and back to something else. Rebooted and switched again. Maybe I should try the 2.1. I’ll let you know if it works.
